Somebody please help (installing pedals)
fuk tha man!
Ok I probably sound like an idiot....I bought a set of Ractive pedals, nice chrome ones...anyways, I installed the clutch and brake fine, but I can't install the gas pedal......somebody please give me some direction on how to...
thanx
thanx
fuk tha man!
that's the thing fellas no instructions, but yeah I took some pics....this is what I got to work with.....
2 long screws, 2 small screws...a long soft aluminum bracket and small something else...and a double sided 3m type sticky tape....
here are some pics...
hope you guys can help.....
Re: Somebody please help (installing pedals)
Oh thank god I found this thread. I have the SAME exact problem. The clutch and brake are easy, but the gas pedal is impossible to figure out. The instructions on the back have three different gas pedals and none of them match the one in my set. I'm hoping to not have to drill into the original pedal. Is there any way to do this?
It seems like there has to be a way. I mean, why would they give you all this other hardware without having to use it?
I rigged it all up so that bracket just wraps around the pedal, but it could easily slide off. I definitely need something more secure...
bump for more info!
bump for more info!
The clutch and break pedals are metal once you remove the rubber outter portion. I drilled right into these and used rivets to secure my type-r pedals. As for the accelerator pedal, its plastic without any removable cover. I drilled into this one too and I believe I used flathead screws instead to keep it in there as opposed to rivets.
I assume this will answer your question. If not, post up what kind of hardware it came with and a shot of the pedal.
fvckbg
Jul 7, 2015 07:08 PM
Causemo
Jul 5, 2015 06:42 AM
Causemo
Jul 4, 2015 07:11 AM
