where is the belt tensioner
where is the belt tensioner on the cam belt? Not the power steering and alt. belt. The one that actually goes around the cam gear. It has some slack in it and is making alot of noise. I need to tighten it but dont know where the tensioner is. Any help would be great.
ok first... its under the water pump about midway up the case.
Now if your tensioner is making noise and or not doing its job (making slack in belt tension)
You HAVE to replace the tensioner you can't just tighten it.
If your timing belt is loose DO NOT DRIVE YOU CAR you are risking more damage.
The tensioner is an auto tensioner, when its bad, its bad. And while you are doing that you also replace the belt. Depending on your mileage you may also want to replace the water pump.
how will I know if the timing belt is loose or needs to be replaced? I dont want to mess with it if it isn't bad. I just have a rattle that sounded like it was coming from inside there.
OptimisticWay
46
Oct 15, 2015 02:16 PM
WaryDriver
Aug 16, 2015 11:22 AM
loosescrew84
16
Aug 11, 2015 07:08 PM
WaryDriver
Aug 8, 2015 05:08 PM
1khilari
Jul 9, 2015 08:12 PM
