K20A vs. K20A2 --> (differences?)
Old Jul 28, 2003
tekgnosis's Avatar
Ask me about your mom.
Hey guys
ok, firstoff let me say this: I've searched and searched for this already, but when you search for it, anything from soup to nuts shows up. So I thought I would ask here if anyone knows the answer to my question.
My question: Does anyone know all of the differences between the K20A (DC5R) and the K20A2 (RSX-S)? I don't mean the obvious (horsepower, torque, LSD, etc...just interested in the internals that are different)
I'm interested in purchasing a K20 of some sort (either the type-R or the type-S), but I'm not sure if the type-R is worth the extra money?
I'm going to get TODA racing cams and valvesprings, as well as their ECU. I'm also going to get an intake manifold, and get aftermarket pistons (not sure which ones yet).
Is the K20A worth the extra money? Or should I just stick with the K20A2?
I'm not sure if the VTEC is any different? ie: does the type-R have the VTC, whereas the type-S doesn't?
I'm lost. any help would be great.
thanks!
Old Jul 28, 2003
prawdigy's Avatar
prawdigy is an unknown quantity at this point
i think the dc5r is worth the extra money.. its 240hp compared to 200 and its jdm..so everything is better..
Old Jul 28, 2003
RedDragon333's Avatar
From all the research i have done it all really boils down to whether you have plans for a turbo setup or not. IF you want the higher redline N/A setup go with the K20A if your desire is for a turbo setup then go for the lower compression of the K20A2.
Here is a few things i came up with in my research for an answer to the same question your asking.
Type R DC5
Engine type K20A
Cylinders/valves Watercooled IL-4
Bore and Stroke (mm) 86.0 x 86.0
Piston displacement (cc) 1998
Compression ratio 11.5
Max power (NET) kW(PS)/rpm 162(220)/8000
Max torque (NET) N.m(kg.m)/rpm 206(21.0)/7000
Fuel system Honda PGM-F1
(Electronic Fuel Injection System)
Gear Ratio
1st Gear Ratio 3.266
2nd Gear Ratio 2.130
3rd Gear Ratio 1.517
4th Gear Ratio 1.212
5th Gear Ratio 0.972
6th Gear Ratio 0.780
Reverse Gear Ratio 3.583
Final gear ratio 4.764
Steering / Suspension / Braking System
Steering Rack & pinion
Suspension (F/R) McPherson / Double wishbone
Braking system (F/R) Oil pressure discs
Performance
0 - 100 km/h 6.0 secs (est)
Top Speed 145 mph (est)
Max mph 146
0 - 30mph 3,0
0 - 40mph 4,2
0 - 50mph 5,4
0 - 60mph 7,1
0 - 70mph 8,9
0 - 80mph 10,9
0 - 90mph 13,8
0 - 100mph 16,7
0 - 110mph 21,2
0 - 120mph 26,1
TED 4,8
1/4 Mile 15,4 sec / 96mph
Type S
2.0L DOHC 16-Valve Engine
i-VTEC (w/ VTC)
Alternator
12V, 95Amp
Aluminum Alloy L4
Bore & Stroke (mm)
86 X 86
Compression Ratio
11.0 : 1
Displacement (cc.)
1998
Emission System
Designed To Meet US EPA / Environment Canada Stringent 2004 Tier-2 Standards
Fuel System
Programmed Fuel Injection (PGM-FI)
Full Electronic Direct Ignition System
Horsepower @ rpm (SAE Net)
200 @ 7400
Redline
7900 rpm
Torque (lbs.-ft)
142 @ 6000
Valvetrain
4 Valves; Chain Driven
Final Drive Ratio MT
4.389
This is just a little information i put together to help me decide. I want a turbo setup so im leaning towards the Type S swap
Old Jul 28, 2003
tekgnosis's Avatar
I'm planning on going the NA route.
but, I'm planning on building it up, too. so I would get higher compression pistons, do a port & polish, get a better intake manifold, etc.
regardless of which engine I get. I'm just wondering if I would be "settling" for the type-S, or if its just not worth the extra money? (for the type-R)
Old Jul 28, 2003
Majarvis's Avatar
Majarvis should not be trustedMajarvis should not be trustedMajarvis should not be trustedMajarvis should not be trusted
The engine you speak of is 220 hp, not 240 hp.
Old Jul 28, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
the K20A from a civic Si will allow you to slap on a
jackson racing supercharger.
Old Jul 28, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
VTC is part of VTEC. ANY engine with VTEC (including the lowly D series) has VTC.
VTEC= Variable Timing Electronic Lift Control
VTC= Variable Timing Control... thats the variable timing part... then the lift control is the other piece of VTEC.
I personally don't think it's worth the extra money for the K20A... don't forget if anything ever breaks on it... you need to get parts from Japan. The Availability of general maintainance parts would push me to get a K20A2, not to mention that you can build the A2 every bit as good as a K20A.
The K20A is from the Integra Type R. The Si is K20A3. There is a JRSC kit for the K20A2 from the Type S, but JR sucks ***** anyways.
Old Jul 28, 2003
HondaLuver's Avatar
Its a celebration bitches!
just get the type R, it is just better, anyways... when you want to turbocharge it, just upgrade the pistons, rods. i think the valves and springs are good enough, in a mag, i read, the top fuel turbo charged type R did need them changed and that car is pushing 500hp turbo charged o yea and it is stroked to 2.4l
Old Jul 28, 2003
cosmo's Avatar
cosmo is an unknown quantity at this point
LSD!! Much nicer then not having it. Flywheels lighter in the K20A too so it'll rev faster and drop off quicker. Other then that which has been mentioned I hvae no clue.
Old Jul 28, 2003
CivicHX01's Avatar
also keep in mind that the k20a needs much higher octane gas which is not available at any gas station (i think very few do) so this means your gonna end up spending lots of money on octane boosters in the long run...
the type-s is available here in the u.s. which should make it cheaper and easier to obtain and it also uses regular gas which will save you money in the long run...
i say if your gonna make your car a daily driver, go for the type-s... if your gonna go for a pure race NA setup, go for the type-r...
Old Jul 28, 2003
OMega's Avatar
OMega is an unknown quantity at this point
Dam, I can't belive people FI these thing without changing the pistons. Man 11.0 and 11.5 that fricken high. What are they running stock on the psi?
Old Jul 28, 2003
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
I agree with what CIVICHX01 said and what BoilerMaker01 said. They both mentioned VERY important facts that I'll definitely want to consider when I'm deciding which engine to get. FOr convenience sake, I'd definitely go with the k20a2 (RSX-S). I dun plan to spend so much extra $$ on gas and octane boosters, and importing replacement parts from Japan (super costly and inconvenient). Bottom line, k20a2 is the way to go, build it, turbo it...just as good, if not better than k20a.
Old Jul 28, 2003
tekgnosis's Avatar
ok, that was a point I don't think I mentioned...
I was worried about the high octane gas I would need.
but, if I get a type-S, and do the following (see below), wouldn't that cause me to need high octane gas anyways?
Mods in the future for the type-S:
1) pistons & rings
2) rods
3) port & polish
4) cams
5) cam gears
6) msd ingition
7) exhaust/intake manifolds
8) intake
9) head gasket
10) con rods
11) valvesprings
(note: the order is retarded because that's the way I think )
...and I can't think of the other internal stuff off the top of my head...but...you get the picture. This will be a daily driver, btw.
anyone know about the octane situation? I
isn't the higher compression the reason for the octane increase? with higher compression pistons, won't that require the use of a higher octane gas to perform at near 100% efficiency?
any help on these questions would be great!
although, I must say...I'm leaning towards the type-S, and then getting a hold of the LSD from the DC5R. hrm....
Old Jul 28, 2003
Jodster's Avatar
Post Whore General
There is a guy on ephatch.com(he goes by Port) and he has the K20A(RSX type R) motor swapped in him SI. And he has no problem running on 93 octane gas. He does put race fuel it for the track.
Old Jul 28, 2003
tekgnosis's Avatar
you CAN run on the low octane...but you're not running anywhere near 100% efficiency.
that's the problem
hrm...I'll see if I can talk to that guy. thanks Jodster!
Old Jul 28, 2003
zinkyroo's Avatar
cool beans
zinkyroo is an unknown quantity at this point
You need a whole type r front clip in order for it to work
Old Jul 28, 2003
tekgnosis's Avatar
that's not a problem.
money...is an issue, but not a huge one. I'm not going to rush into it like a fool. This will be the ONE thing I actually do right -- the first time hehehe
Old Jul 28, 2003
tekgnosis's Avatar
wait...I just read that the way japan rates octane is different than north america?
is their 101 octane our 93 octane???
hrm...
Old Jul 28, 2003
NoBottleJustThrottle's Avatar
NoBottleJustThrottle is an unknown quantity at this point
The R motor isnt worth it. Toda Cams and valve springs with the upgraded ECU wont do much of anything on an R motor. It already has the agressive cams on it. I dont know what emissions is like where you are at either, but the R motor wont pass, the S will. For what you get, i dont think that its worth the extra 2 grand, and not have it legal. People say that they have seen R motors with 500hp and such, and i ve said time and time again, how are you gonna get that to the ground? People think that the more HP the faster that you will go, thats true up to a point. It eventually gets to a point to where you can even hook. Get the S motor with Hondata ECU, CAI, Race Header, and Exhaust and run a mid 13 all day.
Old Jul 28, 2003
HondaLuver's Avatar
how about a type r motor with intake and exhaust and run low 13s all day
Old Jul 28, 2003
hankscorpio's Avatar
hankscorpio is an unknown quantity at this point
hrm...
It actually converts to about 94.5 octane here, and someone with the type R engine said running 93, which is available here, runs fine with no knocking.
Old Jul 28, 2003
cvcpwr2k2's Avatar
cvcpwr2k2 is an unknown quantity at this point
so is it even remotely possible to turbo a type-s? if so how costly?
Old Jul 28, 2003
HondaLuver's Avatar
turbo a type S engine? are you serious...man i wish someone would make a turbo for a type S engine...
if there would be a turbo type S the turbo kit would probly cost like 3,000, it should come out soon...
GReddy
HKS
cybernationmotorsports
Old Jul 29, 2003
tekgnosis's Avatar
but there's no sense in turbo-ing the type-s.
the premium rsx engine has lower compression, and would be a better candidate to do it!
you can make a custom turbo for relatively cheap if you know what you're doing. then again, this is speaking from a backyard-do-it-yourself-homemade type thing
but good point about the type-R not making much more HP with the cams and such.
however, toda specifically says its also for the type-R, and says it will also gain HP?
I think I'm going to stick with the Type-S. The 20hp at the crank can be easily found through other means for cheaper than the difference in price. plus, the whole emmissions thing kinda scares me
then again, up here in ontario, you only have to spend a maximum of $200 every two years to try and get it to pass emissions. if I'm running the type-R, I'm not worried about dishing out an extra $100/year that's chicken feed!!!
(compared to the price of the whole swap)
cool, thanks for the opinions guys! I think I've made up my mind, and I'm going to go with the type-S, and then try to macguyver in the LSD!
thanks!
Old Jul 29, 2003
Jap-Euro Fusion
You don't need to maguyver anything... Quaife and Spoon are already in the works... if they haven't already come out.
Old Jul 29, 2003
HondaLuver's Avatar
all in all the type R engine is better made... than the S, and is made to take a harder beating...
and just by saying "i swaped a type R" is going to get alot more respect than a type S
remember, its all about respect...
Old Jul 29, 2003
HondaLuver's Avatar
to some of you, respect is better than other things
Old Jul 29, 2003
Bellz's Avatar
Respect? Pfah! If i swapped, it'd be for MY enjoyment. I wouldn't tell anyone i had a type-s/r in there until I dusted them.
Old Jul 29, 2003
Green Civic's Avatar
I know someone that has the K20a in their SI. He runs 93 octane. He has a SRI and ehaust (I believe). He's running low 14's with 15" or 16" rims. He has no detanation problems with running 93 at the pump. You can mix a little 101 octane to increase the octane. He runs it down at the No Problem Raceway in LA. Im thinking of going with the K20a2 myself. Its a U.S. engine. I dont have to go to a specialist for engine work. Emisions is not a problem for me. May go with some type-r internals or run a turbo. Not sure just yet.
P.S. The K20a3 is a SI engine as well as the RSX base model engine.
Old Jul 29, 2003
civicskater's Avatar
Chicks dig my scent
the Type-S motor has 3 rocker arms on the intake valves and exhaust valves, also unlike the Si K20 motor VTEC and VTC affects the exhaust valves, not just the intake valves causing more power to be made there. Which is some crazy way to add the 40hp plus some other gearing and products changes
But in the latest Import Tuner they did a TODA cam swap on a K20A2 motor and it gained 26whp...check it out
import tuner
