Aftermarket Shifter w/ Stock Boot
Old Jul 16, 2003
NCStyle's Avatar
Lax Playa
NCStyle is an unknown quantity at this point
I have an aftermarket shift **** (Sparco) and it is made to screw into a shift boot. But when you take off the stock shift ****, it snaps in and out of the boot, so once i put on the ****, it doesn't connect with the boot. Is there any way to get our boot to fit onto the **** and look normal?
Old Jul 16, 2003
xtiszx's Avatar
Cracka
xtiszx is an unknown quantity at this point
If i remember, someone made or talked about a DIY for that, id do a search if you havent already,
Old Jul 17, 2003
clownprince's Avatar
Ricerus Maximus
I had the same problem ans here's how I fixed it.
1. Look at the position of the shift **** on the shifter and see how high you need to have the boot sitting to fit flush with the ****.
2. remove the entire center console (you can just remove the black parrts the go over the ebrake and shifter but it's just as easy to remove the whole console.
If you don't know how to do that, remove the 2 screws at the rear of the console and the 2 pop clips at the front. Pull towards the rear of the car a little and then up and out.
3. With the console removed, put the **** back on the shifter. Look at the shift boot and you will see that in the middle of that clip there is a circle that the shifter goes through. Estimate where it is that the bottom of that piece will sit (on the shifter) when the boot is pushed up flush with the ****.
4. Wrap electrical tape around the shifter at that point. Make it thick ( I believe about an 1/8 in. thick is what I did. Yes, it takes a lot of tape. Put the console back in the car but don't screw it down yet. The shift boot should sit in the raised position and not fall down, being that it is held up by the tape. Put the **** on the shifter and see if the boot sits flush with the ****. If it neds raising or lowering, remove the **** and console and try again. It shouldn't take to long to get it looking right. When finished, the **** should sit flush with the boot so that the boot has no up and down travel.
PM me with any questions that you have.
Old Jul 17, 2003
xtiszx's Avatar
Cracka
thats a great small cheap fix, good info
Old Jul 17, 2003
R3DL1N3's Avatar
ive got a momo sphere and it looks pretty cool like it is imo
Old Jul 17, 2003
Ricerus Maximus
Thanks
I hate to admit this but I did this because I bought the Chrome cobra head shifter **** (earlier ricier days) from AUto Zone and had to keep the boot up. That has since been replacecd with a 2000 SI **** and the clips on it are the same as my old stock one. The tape is still there and doesn't interfere at all. And the funniest part, there is a blue SI in town riding around with that tall gay 01 shift **** in it. I know the guy and he has no clue as to the difference although he likes the **** in my car. Doens't know that it was once in his car, or that he has my old ****. Ah the perks of working at a dealership.
Yes, I did this before he bought the car off of the lot so he's had the 01 **** since purchasing the car.
Old Jul 17, 2003
xtiszx's Avatar
Cracka
ahhahahahha, good one bro
Old Jul 17, 2003
poor jaysun's Avatar
poor jaysun will become famous soon enoughpoor jaysun will become famous soon enough
A simple way.
Get some 3M 2 sided tape (black) and place it inside the top ring of the shifter boot and most shifter ***** are tapered at the bottom and attach it using the tape. Done
Old Jul 17, 2003
Renamazazo's Avatar
Renamazazo is an unknown quantity at this point
For my shift ***, I went to Ace hardware and bought a 5/8th's inner diameter collar with a set screw. Then I fed the top of the boot (you have to remove the gray coller thingy for this to work) through it and positioned it where it needed to be and tightened the hell out of it. It Looks great, I'd post pics but I have no digital camera handy...
Old Jul 18, 2003
skaterboy's Avatar
skaterboy is an unknown quantity at this point
Re: Aftermarket Shifter w/ Stock Boot
maybe u didnt install it right? Read ur manual...
Old Jul 19, 2003
ptechricer's Avatar
ptechricer is an unknown quantity at this point
I would just buy an after market boot and be done with it.
Old Jul 19, 2003
NCStyle's Avatar
Lax Playa
Yeah I wouldn't mind buying an aftermarket boot but I dont know where one is that fits our car, anybody gonna hook me up with a link?
UltraHDGames
Jun 8, 2016 05:16 PM
bhollie
Sep 22, 2015 11:08 PM
Mucklow
Aug 22, 2015 06:28 PM
Nikipedia
Jul 28, 2015 10:50 PM
7thgensurvivor
Jul 5, 2015 12:17 PM
