High Idle After dropping engine
Old Jul 15, 2003
NoToRiOuSxPiNoY's Avatar
Sekz God
NoToRiOuSxPiNoY is an unknown quantity at this point
Angry High Idle After dropping engine
Err Me and a couple mechanic friends of mine just dropped another factory engine in my car. Since warranty and insurance wouldnt cover anything after my car hydrolocked.
The car is running but it idles at near 2000 rpm. and it goes up and down and plus the check engine light is on. Now we checked why the engine light is on.. it says the Idle Air Control is malfunctioning.. dont know what dat means.. so can someone help me out!!!!?
Old Jul 15, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
I'm assuming that you have done the obvious and checked/adjusted the throttle cable....
Old Jul 15, 2003
Sekz God
I mean it looks like it is... but even that wont turn the check engine lite on.. you know..
Old Jul 15, 2003
ak's Avatar
ak
Retired Mod
Idle air control...hmm...... IAC.... reminds me of the Intake Air Temperature sensor... no relationship?? The sensor that plugs into the intake.
Old Jul 15, 2003
Sekz God
Its reving real high... can someone show me a picture of the throttle body cable up close... like real close
Old Jul 15, 2003
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
One of four things.
1. Loose vacuum line underneath intake.
2. Corrupted programming or wrong programming in ECU.
3. Damaged wire from ECU to Idle Control Valve.
4. Faulty IAC.
I might be able to help more if you gave me the exact DTC.
Old Jul 16, 2003
Sekz God
for the check engine code it says code 505. Idle Air Control malfunction. It revs and shakes at park..... up to 2000 rpms.... then drops a bit then revs back up.
Old Jul 16, 2003
Sekz God
It only happens really wen im on park..
Old Jul 16, 2003
Nodnero's Avatar
Interesting, so once in gear it calms down? I would think ECU, but I would take it in. Since you dropped another engine, is it still a D17A? As long as you have all the correct paperwork, I would think that Honda would still have it covered under warrenty but Im not a for sure on that.
Old Jul 16, 2003
Sekz God
Its still the same engine... same year same model... Honda wont cover it unless they did the work.. engine swap was just too simple for me to pay for it lol.
Old Jul 17, 2003
CIVIC808's Avatar
CIVIC808 is an unknown quantity at this point
Originally posted by rickinthescv
One of four things.
4. Faulty IAC.
right from the manual.if you still have the other engine you can try and swap the iac.but do one and three first.
Old Jul 17, 2003
Slumpert's Avatar
Slumpert is an unknown quantity at this point
You might have a "Bad" sensor now. The sensors on the intake were never meant to go swimming, not to mention that charcoal canister.
Slump
Old Jul 17, 2003
Mr.Modify's Avatar
CHECK THE THROTTLE CABLE!!!! I ACCIDENTALLY TIGHTENED MINE UP TO MUCH AND IT WAS DOING THE SAME THING EXCEPT IT SOUNDED LIKE I WAS ON THE ****ING FREEWAY I BET IT'S THE THROTTLE CABLE!!!! TELL US WHAT IT WAS WHEN YA FIX IT!!!!
Old Jul 17, 2003
Alex1's Avatar
make sure the rear mount is on tight, it used to happen to my other civic too, 2001 EX. it shakes and idle is rough on park and neutral.
Old Jul 17, 2003
CIVICONBAGS's Avatar
CIVICONBAGS is an unknown quantity at this point
It definately WOULD NOT be the throttle cable or else the DTC would most likely come out as a TPS code if any... rick has the right set of mind on this... go get an volt meter from one of your mechanic buddies and check the circuit for any shorts, opens, or check with the ohn meter for low or high resistance
Old Jul 17, 2003
PM me with your email address and I will send you a PDF of the instructions for testing.
Peace
Old Jul 18, 2003
skaterboy's Avatar
skaterboy is an unknown quantity at this point
I had same problem when my frined and I drop the B18... I tried to fix it and realized that my vaccume line was leaking... I was like what... And check ur throttle body too.. There might be a leak, too... By the way, did you change ur ecu if you drop the higher motor?
Old Jul 18, 2003
flotsamm's Avatar
IAC is a sensor that controls the butterfly valve position. Its mainly used to set the idle high when the engine is cold so it warms up quicker. As the engine warms up, it drops the rpms accordingly. Its like a choke on a carburator. I would double check your wiring to the IAC or even take it out and get it tested or replaced. Also check and make sure that your butterfly valve is moving fine.
Old Jul 21, 2003
DaPipeLayer's Avatar
AAAAHHHHH!!!!!
DaPipeLayer is an unknown quantity at this point
I have the exact same problem right now. My car will idle real high and then drop very low like it was going to turn off. My car did get hydrolocked but I was able to save it. It drives fine but its like you say, when I'm sitting at the light or just parked, it idles rough and the rpm goes up and down.
Old Jul 22, 2003
AAAAHHHHH!!!!!
I took my car to the dealer and they said that the computer was just throwing codes out for things that weren't even damaged and it just conflicted with itself. So they just reset the computer and everything is fine now. Thank god is was something very simple.
Old Jul 23, 2003
Restin's Avatar
Restin is an unknown quantity at this point
Check and try the following.....
Check......
Is throttle cable adjusted...
Are sensors mounted properly and tight...
Make sure air filter or intake which ever you have is properly put on and secure...
If those are ok, reset the ECU by leaving the battery unplugged for 30 minutes, no less that that or it won't reset. Hook it back up and give it 2 days to let ECU adjust itself.
mikemc422
Aug 9, 2018 05:41 PM
crowtoo
May 11, 2015 06:50 PM
oqjoi
Transmission
May 6, 2015 06:27 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
1stcivic
Nov 18, 2001 09:17 PM
