ATTN: VNLilMan and others
I have a problem i believe.
I have eibach sportlines with eibach camber kit and stock shocks.
i have 2 subs in a closed box in trunk as well.
well on the rear right side when i turn and put pressure on that side of the car it sounds like a something is slightly popping when pressure is put on that side. i am not sure if its just the springs or what but, my shocks seem fine when i bounce the rear of the car up and down. The sound is very quite not loud at all just enough to make you notice. It almost sounds like something is grinding together back there. should i worry about this???
Thanks,
Injen
Thanks,
Injen
im not sure what might be wrong, but take out the whole strut and re-tighten the top nut that holds in the spring. then put it back and make sure you tighten everything else. if it still makes that noise, check the camber kit (stock or aftermarket) and make sure nothing is loose. inspect everything on that side, even the sway bar and endlinks (if you have an EX).
those are the only problems i can think of.
hope this helps
hope this helps
i hear a very quite popping sound in the back of my car, i have skunk2 coilovers, stock shocks and also have 2 12's in a box in the trunk. i am sure my shocks are blown, and i think the sound is coming from them. you should check your shocks because maybe you just can't hear the sound when your bouncing the rear up and down. hope this helps
ok i checked all those things and everything seems fine!!! so what do you think it is now???? The shock doesnt sound like its blown cause i have heard one of those before. its still rides fine just makes that grinding sound kinda but very small noise to notice.
Injen
Injen
Originally posted by DizWikedCivic
u sure the spring on the rear is on the strut right
Injen
just take out your rear susupesion, it not that hard, just 2 nuts and 1 bolt
Injen
Originally posted by injencivic
i cant get to it because of my cover over the tire and the fender well. the thing that the net in your trunk attaches to on the ends of your trunk i cant get that off.
Injen
Injen
TopFuel
South Cali
150
Jun 20, 2004 11:16 AM
