ATTN: VNLilMan and others
Old Jul 3, 2003
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
I have a problem i believe.
I have eibach sportlines with eibach camber kit and stock shocks.
i have 2 subs in a closed box in trunk as well.
well on the rear right side when i turn and put pressure on that side of the car it sounds like a something is slightly popping when pressure is put on that side. i am not sure if its just the springs or what but, my shocks seem fine when i bounce the rear of the car up and down. The sound is very quite not loud at all just enough to make you notice. It almost sounds like something is grinding together back there. should i worry about this???
Thanks,
Injen
Old Jul 4, 2003
injencivic's Avatar
nobody have a clue???
Injen
Old Jul 5, 2003
Weaponx12o's Avatar
im not sure what might be wrong, but take out the whole strut and re-tighten the top nut that holds in the spring. then put it back and make sure you tighten everything else. if it still makes that noise, check the camber kit (stock or aftermarket) and make sure nothing is loose. inspect everything on that side, even the sway bar and endlinks (if you have an EX).
those are the only problems i can think of.
hope this helps
Old Jul 5, 2003
JRS1civic's Avatar
JRS1civic is an unknown quantity at this point
i hear a very quite popping sound in the back of my car, i have skunk2 coilovers, stock shocks and also have 2 12's in a box in the trunk. i am sure my shocks are blown, and i think the sound is coming from them. you should check your shocks because maybe you just can't hear the sound when your bouncing the rear up and down. hope this helps
Old Jul 5, 2003
Weaponx12o's Avatar
yea. check if your shocks are leaking. look at your rims any liquid on them
Old Jul 5, 2003
injencivic's Avatar
ok i checked all those things and everything seems fine!!! so what do you think it is now???? The shock doesnt sound like its blown cause i have heard one of those before. its still rides fine just makes that grinding sound kinda but very small noise to notice.
Injen
Old Jul 5, 2003
DizWikedCivic's Avatar
u sure the spring on the rear is on the strut right
Old Jul 6, 2003
SlammedBlueEM2's Avatar
All Eyes On Z
If you have an EX, did you check the anti sway bar?
Old Jul 6, 2003
injencivic's Avatar
well from looking from underneath my car yes it looked like it was. But i couldnt tell through the trunk
Injen
Old Jul 6, 2003
injencivic's Avatar
ya i checked it, its fine
Injen
Old Jul 6, 2003
just take out your rear susupesion, it not that hard, just 2 nuts and 1 bolt
Old Jul 6, 2003
injencivic's Avatar
i cant get to it because of my cover over the tire and the fender well. the thing that the net in your trunk attaches to on the ends of your trunk i cant get that off.
Injen
Old Jul 6, 2003
Injen
isnt the net in the middle of the trunk, the rear sususension is way in the back
Old Jul 6, 2003
injencivic's Avatar
at the top and middle of the trunk is where it connects. i will try it again but i am not sure. where is Vnlilman at?
Injen
VNlilMAN
South Cali
31
Nov 26, 2017 03:04 AM
TopFuel
South Cali
150
Jun 20, 2004 11:16 AM
Nodnero
South Cali
30
Nov 13, 2003 01:06 PM
RIC3BOY
Aug 18, 2003 10:16 AM
yourinmyw0rld
Engine Swaps
Jul 10, 2003 02:27 PM
