SRS light question
SRS light question
When i turn my car on my srs light flashes for about 6 secs then turns off. could i just disconnect my battery to reset this light?
Injen
Injen
Originally posted by EManEX
I thought it was supposed to flash.
Injen
Originally posted by YS
DIY : Reset SRS Light
i know where that is and about that but i was askin another question.
Injen
Originally posted by jamesj
Mine blinks, it's when it stays on that you have to watch out for. I had a laptop trip the circuit and then some fatass friend of my ex-girlfriend tripped it too.
Injen
Sit on the laptop? HA! Nooo... it was just a situation fatass to passenger seat and it actually tripped the circuit. I was stuck driving the friend around and I didn't realize our SRS seats had a weight limit.
i did the srs light reset, but one question do you plug the mes connector back in before you turn your ignition off? or before you turn it back on?
"5th Disconnect SCS service connector from MES connector within 4 seconds. SRS indicator light will indicate that memory is erased by blinking 2 times.
6th Turn ignition off, and wait 10 seconds. Start vehicle like normal and light should come on and go out like normal. You have reset your SRS light, congrats. "
mine did that for a while.. then the check engine light came on and wouldnt go off... so i went to a garage that my friend's dad owned, had a mechanic look at it. all he did was turn it on and leave it running for about 15 minutes, and all the warning lights and such worked like the day i took it from the dealership.. try that.. just let it idle for days..
Blazz
May 25, 2015 10:56 PM
jimmyfloyd
May 20, 2015 07:06 PM
SimDogg
Nov 27, 2001 04:20 PM
