cant get off drum cover
Old Jun 30, 2003
Da1lyDr1ver's Avatar
does anyone know what the best way of getting off the drum cover to access the rear brakes. i know if it gets stuck you're supposed to hit it with a hammer, but i kept hitting it for a while and still its not getting any loose.
Old Jun 30, 2003
SlvrLx26's Avatar
Video Game & Movie Whore!
SlvrLx26 will become famous soon enough
Try releasing the handbrake!! Then wiggle it side to side . Then tap on different partsof the inner rim of the drum!
Old Jun 30, 2003
trashguy's Avatar
trashguy is an unknown quantity at this point
isnt there two screw holes you can put screws in to help push off the drum... I know there are ones on the front rotors.
Old Jun 30, 2003
orso's Avatar
orso is an unknown quantity at this point
i watch the tech's at honda and all they did was take a bolts and screwed it into the holes. came right off. took two seconds.
Old Jun 30, 2003
what bolt are you talking about, and yes, the e-brake was off
Old Jul 1, 2003
HomerSimpson's Avatar
You just have to be forceful to get it off.
Old Jul 1, 2003
dj02's Avatar
in the middle of ur rear brake there is a cap. take that cap off, then ur going to see a nut. its a big one take that nut off, and ur cover will come right off.
Old Jul 1, 2003
Logan's Avatar
Logan is an unknown quantity at this point
I probably remove 3 or 4 sets of drum brake covers a day and never had a problem with it so far. Just gotta hit it right on the edge at the right angle with a good amount of force. Don't be afraid to take a good whack at it if it's being stubborn...very hard to mess it up. Oh yah...you probably already know this...but I hope you're using a RUBBER mallet, hehe.
Old Jul 2, 2003
trashguy's Avatar
Lol im pretty sure its a 6mm stud that u use and u put them in the two holes on the drum that have threads... when you evenly tighten them it pops the drum off.
Old Jul 4, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
after u take the center bolt off... hit one sidewith a hammer and it will pop off...
SammySC
121
Apr 7, 2017 07:43 PM
Raiool
Oct 1, 2015 10:42 AM
Hutch1051
Sep 29, 2015 09:20 AM
Bruce2
Sep 27, 2015 08:45 PM
jsmithe2010
Sep 25, 2015 07:42 PM
