- ECM Removal/Replacement Steps
- Code Reader cannot communicate with ECU/PCM - Guide for stock ECU swaps
- DIY: Replacing Backlight Illumination Bulbs
- how to get key copies
- DIY: Radar Scanner Hardwire with Remote Mute
- question about 07 civic oem navigation on a 02 civic
- DIY: EP3 component speaker install w/ pics
- DIY: SRS Codes and reading them
- how do you properly reset the ecu
- Carputer D.I.Y.
- DIY: 01-03 to 04-05 Gauge Cluster Swap
- DIY Alternator High Output Upgrade
- DIY: Radar Detector Hardwire
- Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
- DIY: DEI (viper/clifford..) RStart/keyless/alarm INSTALL
- VAFC II Full Installation Info
- Update for EMANAGE: WORKING SETUP FOR EXs!!!
- A'PEXi Rev/Speed Meter Install
- Installing Oil Gauges
- 98-01 Accord Trunk Opener on 7thGen Civic
- Air/Fuel Gauge Install
- Turbo Timer
- VTEC Light (with Pics)
- A'PEXi VAFC Install #2
- A'PEXi VAFC Install #1
- Replace Stock With Aftermarket Horn
- Push Button Ignition
- Shutting off A/C during defrost mode
- Extra Power Outlet
- Reverse Indiglo Gauges
- Installing a Tach
- Reset Your SRS Light
- Installing A'PEXi S-AFC
- A'PEX'i V-AFC Install Instructions
- Alarm, Remote Start and Audio Wiring Chart
