Legal Questions and the Law Post your questions about the law, or speeding tickets or any legal issues here.
Disclaimer: Civicforums.com and it's moderators are not lawyers or police officers and can in no way be held responsible for any advice or action
FYI Virginia Modification Laws
Old Oct 19, 2004
AceKicker's Avatar
AceKicker is an unknown quantity at this point
Here are the laws the cops use in court hope this helps some people. If can be made sticky for everyone thanx. here is the list of laws I posted
Mufflers
Exhaust systems
Suspension Mods
Radar Detectors
In Car TV's
Racing Seats
Racing Harnesses
Nitrous Oxide
Tint,Signs,Decals
Here is the Link for all the laws Cops use for motor vehicles
Vehicle Laws and Codes
Vehicle Inspections Codes make sure your in chapter 70 all the inspection codes are there.
Exhaust Mod 1
§ 46.2-1047. Muffler cutout, etc., illegal.
It shall be unlawful to sell or offer for sale any (i) muffler without interior baffle plates or other effective muffling device or (ii) gutted muffler, muffler cutout, or straight exhaust. It shall be unlawful for any person to operate on the highways in the Commonwealth a motor vehicle equipped with a gutted muffler, muffler cutout, or straight exhaust.
(Code 1950, § 46-306; 1950, p. 54; 1958, c. 541, § 46.1-302; 1964, c. 628; 1989, c. 727.)
Exhaust Mod 2
§ 46.2-1049. Exhaust system in good working order.
No person shall drive and no owner of a motor vehicle shall permit or allow the operation of any vehicle on a highway unless it is equipped with an exhaust system of a type installed as standard factory equipment, or comparable to that designed for use on the particular vehicle as standard factory equipment, in good working order and in constant operation to prevent excessive or unusual noise. An exhaust system shall not be deemed to prevent excessive or unusual noise if it permits the escape of noise in excess of that permitted by the standard factory equipment exhaust system of private passenger motor vehicles or trucks of standard make.
The term "exhaust system," as used in this section, means all the parts of a motor vehicle through which the exhaust passes after leaving the engine block.
Chambered pipes are not an effective muffling device to prevent excessive or unusual noise.
(Code 1950, § 46-305; 1952, c. 455; 1956, c. 651; 1958, c. 541, § 46.1-301; 1960, c. 120; 1970, c. 266; 1972, c. 66; 1989, c. 727.)
Ride Height(Suspension Mod)
§ 46.2-1063. Alteration of suspension system; bumper height limits; raising body above frame rail.
No person shall drive on a public highway any motor vehicle registered as a passenger motor vehicle if it has been modified by alteration of its altitude from the ground to the extent that its bumpers, measured to any point on the lower edge of the main horizontal bumper bar, exclusive of any bumper guards, are not within the range of fourteen inches to twenty-two inches above the ground. Notwithstanding the foregoing provisions of this section, the range of bumper heights for motor vehicles bearing street rod license plates issued pursuant to § 46.2-747 shall be nine to twenty-two inches.
No vehicle shall be modified to cause the vehicle body or chassis to come in contact with the ground, expose the fuel tank to damage from collision, or cause the wheels to come in contact with the body under normal operation. No part of the original suspension system of a motor vehicle shall be disconnected to defeat the safe operation of its suspension system. However, nothing contained in this section shall prevent the installation of heavy duty equipment, including shock absorbers and overload springs. Nothing contained in this section shall prohibit the driving on a public highway of a motor vehicle with normal wear to the suspension system if such normal wear does not adversely affect the control of the vehicle.
No person shall drive on a public highway any motor vehicle registered as a truck if it has been modified by alteration of its altitude from the ground to the extent that its bumpers, measured to any point on the lower edge of the main horizontal bumper bar, exclusive of any bumper guards, do not fall within the limits specified herein for its gross vehicle weight rating category. The front bumper height of trucks whose gross vehicle weight ratings are 4,500 pounds or less shall be no less than 14 inches and no more than 28 inches, and their rear bumper height shall be no less than 14 inches and no more than 28 inches. The front bumper height of trucks whose gross vehicle weight ratings are 4,501 pounds to 7,500 pounds shall be no less than 14 inches and no more than 29 inches, and their rear bumper height shall be no less than 14 inches and no more than 30 inches. The front bumper height of trucks whose gross vehicle weight ratings are 7,501 pounds to 15,000 pounds shall be no less than 14 inches and no more than 30 inches, and their rear bumper height shall be no less than 14 inches and no more than 31 inches. Bumper height limitations contained in this section shall not apply to trucks with gross vehicle weight ratings in excess of 15,000 pounds. For the purpose of this section, "truck" includes pickup and panel trucks, and "gross vehicle weight ratings" means manufacturer's gross vehicle weight ratings established for that vehicle as indicated by a number, plate, sticker, decal, or other device affixed to the vehicle by its manufacturer.
In the absence of bumpers, and in cases where bumper heights have been lowered, height measurements under the foregoing provisions of this section shall be made to the bottom of the frame rail. However, if bumper heights have been raised, height measurements under the foregoing provisions of this section shall be made to the bottom of the main horizontal bumper bar.
No vehicle shall be operated on a public highway if it has been modified by any means so as to raise its body more than three inches, in addition to any manufacturer's spacers and bushings, above the vehicle's frame rail or manufacturer's attachment points on the frame rail.
This section shall not apply to specially designed or modified motor vehicles when driven off the public highways in races and similar events. Such motor vehicles may be lawfully towed on the highways of the Commonwealth.
(1973, c. 498, § 46.1-282.1; 1978, c. 605; 1980, c. 342; 1986, c. 570; 1989, c. 727; 1991, c. 688; 1992, c. 864; 1993, c. 73.)
Radar Detector
§ 46.2-1079. Radar detectors; demerit points not to be awarded.
A. It shall be unlawful for any person to operate a motor vehicle on the highways of the Commonwealth when such vehicle is equipped with any device or mechanism, passive or active, to detect or purposefully interfere with or diminish the measurement capabilities of any radar, laser, or other device or mechanism employed by law-enforcement personnel to measure the speed of motor vehicles on the highways of the Commonwealth for law-enforcement purposes. It shall be unlawful to use any such device or mechanism on any such motor vehicle on the highways. It shall be unlawful to sell any such device or mechanism in the Commonwealth. However, provisions of this section shall not apply to any receiver of radio waves utilized for lawful purposes to receive any signal from a frequency lawfully licensed by any state or federal agency.
This section shall not be construed to authorize the forfeiture to the Commonwealth of any such device or mechanism. Any such device or mechanism may be taken by the arresting officer if needed as evidence, and, when no longer needed, shall be returned to the person charged with a violation of this section, or at that person's request, and his expense, mailed to an address specified by him. Any unclaimed devices may be destroyed on court order after six months have elapsed from the final date for filing an appeal.
Except as provided in subsection B of this section, the presence of any such prohibited device or mechanism in or on a motor vehicle on the highways of the Commonwealth shall constitute prima facie evidence of the violation of this section. The Commonwealth need not prove that the device or mechanism in question was in an operative condition or being operated.
B. A person shall not be guilty of a violation of this section when the device or mechanism in question, at the time of the alleged offense, had no power source and was not readily accessible for use by the driver or any passenger in the vehicle.
C. This section shall not apply to motor vehicles owned by the Commonwealth or any political subdivision thereof and used by law-enforcement officers in their official duties, nor to the sale of any such device or mechanism to law-enforcement agencies for use in their official duties.
D. No demerit points shall be awarded by the Commissioner for violations of this section. Any demerit points awarded by the Commissioner prior to July 1, 1992, for any violation of this section shall be rescinded and the driving record of any person awarded demerit points for a violation of this section shall be amended to reflect such rescission.
(1962, c. 125, § 46.1-198.1; 1975, c. 108; 1976, c. 90; 1978, cc. 87, 91; 1981, c. 303; 1989, c. 727; 1992, c. 825; 1998, c. 300.)
In Car TV's
§ 46.2-1077. Motor vehicles not to be equipped with television within view of driver.
No motor vehicle registered in the Commonwealth of Virginia shall be equipped with, nor shall there be used therein, a television receiver forward of the driver's seat or the screen of which would otherwise be visible to the driver while driving the vehicle. The operator of a motor vehicle which is not required to be registered in Virginia shall not operate a television receiver which violates the provisions of this section while driving in the Commonwealth.
The prohibitions contained in the foregoing provisions of this section shall not, however, include:
1. Electronic displays used in conjunction with vehicle navigation systems;
2. Closed circuit video monitors designed to operate only in conjunction with dedicated video cameras and used in rear-view systems on trucks and motor homes; and
3. Television receivers or monitors used in government-owned vehicles by law-enforcement officers and employees of the Virginia Department of Transportation in the course of their official duties.
(Code 1950, § 46-219.1; 1950, p. 882; 1958, c. 541, § 46.1-202; 1989, c. 727; 1994, c. 117.)
Racing Seats
§ 46.2-1084. Vehicle to have securely affixed seat for driver; location of such seat.
It shall be unlawful for any person to drive any motor vehicle on a highway in the Commonwealth unless it is equipped with a securely affixed seat for the driver. The seat shall be so located as to permit the driver to adequately control the steering and braking mechanisms and other instruments necessary for the safe operation of the motor vehicle.
(1973, c. 56, § 46.1-302.1; 1989, c. 727.)
Racing Harness(seat belts)
§ 46.2-1093. Requirements for safety lap belts, shoulder harnesses and combinations thereof.
Any safety lap belt or shoulder harness or any combination of lap belt and shoulder harness installed in a vehicle shall be designed and installed in such manner as to prevent or materially reduce movement of any person using the same in the event of collision or upset of the vehicle.
The Superintendent shall establish specifications or requirements for approved type safety lap belts and shoulder harnesses or any combination of lap belt and shoulder harness, attachments, and installation, in accordance with the provisions of this section. Such specifications or requirements may be the same as those specifications or requirements for safety lap belts or shoulder harnesses or any combination of lap belt and shoulder harness established by the Civil Aeronautics Administration Technical Standard Orders or regulations established by the Society of Automotive Engineers or the standards of the federal Department of Transportation, for safety lap belts and shoulder harnesses or combination of lap belts and shoulder harnesses.
No person shall sell or offer for sale any safety lap belt, shoulder harness, or any combination of lap belt and shoulder harness or attachments thereto for use in a vehicle, unless of a type which has been approved by the Superintendent.
(Code 1950, § 46-312.1; 1956, c. 36; 1958, c. 541, § 46.1-310; 1966, c. 37; 1968, c. 171; 1970, c. 20; 1989, c. 727.)
Nitrous Oxide
§ 46.2-1088.4. Devices used to supply nitrous oxide to the engines of motor vehicles.
It shall be unlawful for any person to operate any motor vehicle on the highways of the Commonwealth if such vehicle is equipped with any device that supplies the vehicle's engine with nitrous oxide, unless the device has been disabled such that the supply of nitrous oxide is disconnected and not readily accessible to the source of delivery.
Violation of any provision of this section shall constitute a Class 3 misdemeanor.
(2004, c. 282.)
Tint,Signs,Decals, ETC.
§ 46.2-1052. Tinting films, signs, decals, and stickers on windshields, etc.; penalties.
A. Except as otherwise provided in this article or permitted by federal law, it shall be unlawful for any person to operate any motor vehicle on a highway with any sign, poster, colored or tinted film, sun-shading material, or other colored material on the windshield, front or rear side windows, or rear windows of such motor vehicle. This provision, however, shall not apply to any certificate or other paper required by law or permitted by the Superintendent to be placed on a motor vehicle's windshield or window.
The size of stickers or decals used by counties, cities, and towns in lieu of license plates shall be in compliance with regulations promulgated by the Superintendent. Such stickers shall be affixed on the windshield at a location designated by the Superintendent.
B. Notwithstanding the foregoing provisions of this section, whenever a motor vehicle is equipped with a mirror on each side of such vehicle, so located as to reflect to the driver of such vehicle a view of the highway for at least 200 feet to the rear of such vehicle, any or all of the following shall be lawful:
1. To drive a motor vehicle equipped with one optically grooved clear plastic right-angle rear view lens attached to one rear window of such motor vehicle, not exceeding 18 inches in diameter in the case of a circular lens or not exceeding 11 inches by 14 inches in the case of a rectangular lens, which enables the driver of the motor vehicle to view below the line of sight as viewed through the rear window;
2. To have affixed to the rear side windows, rear window or windows of a motor vehicle any sticker or stickers, regardless of size; or
3. To drive a motor vehicle when the driver's clear view of the highway through the rear window or windows is otherwise obstructed.
C. Except as provided in § 46.2-1053, but notwithstanding the foregoing provisions of this section, no sun-shading or tinting film may be applied or affixed to any window of a motor vehicle unless such motor vehicle is equipped with a mirror on each side of such motor vehicle, so located as to reflect to the driver of the vehicle a view of the highway for at least 200 feet to the rear of such vehicle, and the sun-shading or tinting film is applied or affixed in accordance with the following:
1. No sun-shading or tinting films may be applied or affixed to the rear side windows or rear window or windows of any motor vehicle operated on the highways of this Commonwealth that reduce the total light transmittance of such window to less than 35 percent;
2. No sun-shading or tinting films may be applied or affixed to the front side windows of any motor vehicle operated on the highways of this Commonwealth that reduce total light transmittance of such window to less than 50 percent;
3. No sun-shading or tinting films shall be applied or affixed to any window of a motor vehicle that (i) have a reflectance of light exceeding 20 percent or (ii) produce a holographic or prism effect.
Any person who operates a motor vehicle on the highways of this Commonwealth with sun-shading or tinting films that (i) have a total light transmittance less than that required by subdivisions 1 and 2 of this subsection, (ii) have a reflectance of light exceeding 20 percent, or (iii) produce holographic or prism effects shall be guilty of a traffic infraction but shall not be awarded any demerit points by the Commissioner for the violation.
Any person or firm who applies or affixes to the windows of any motor vehicle in Virginia sun-shading or tinting films that (i) reduce the light transmittance to levels less than that allowed in subdivisions 1 and 2 of this subsection, (ii) have a reflectance of light exceeding 20 percent, or (iii) produce holographic or prism effects shall be guilty of a Class 3 misdemeanor for the first offense and of a Class 2 misdemeanor for any subsequent offense.
D. The Division of Purchases and Supply, pursuant to § 2.2-1112, shall determine the proper standards for equipment or devices used to measure light transmittance through windows of motor vehicles. Law-enforcement officers shall use only such equipment or devices to measure light transmittance through windows that meet the standards established by the Division. Such measurements made by law-enforcement officers shall be given a tolerance of minus seven percentage points.
E. No film or darkening material may be applied on the windshield except to replace the sunshield in the uppermost area as installed by the manufacturer of the vehicle.
F. Nothing in this section shall prohibit the affixing to the rear window of a motor vehicle of a single sticker no larger than 20 square inches if such sticker is totally contained within the lower five inches of the glass of the rear window, nor shall subsection B of this section apply to a motor vehicle to which but one such sticker is so affixed.
G. Nothing in this section shall prohibit applying to the rear side windows or rear window of any multipurpose passenger vehicle or pickup truck sun-shading or tinting films that reduce the total light transmittance of such window or windows below 35 percent.
H. As used in this article:
"Front side windows" means those windows located adjacent to and forward of the driver's seat;
"Holographic effect" means a picture or image that may remain constant or change as the viewing angle is changed;
"Multipurpose passenger vehicle" means any motor vehicle that is (i) designed to carry no more than 10 persons and (ii) constructed either on a truck chassis or with special features for occasional off-road use;
"Prism effect" means a visual, iridescent, or rainbow-like effect that separates light into various colored components that may change depending on viewing angle.
"Rear side windows" means those windows located to the rear of the driver's seat;
"Rear window" or "rear windows" means those windows which are located to the rear of the passenger compartment of a motor vehicle and which are approximately parallel to the windshield;
I. Notwithstanding the foregoing provisions of this section, sun-shading material which was applied or installed prior to July 1, 1987, in a manner and on which windows not then in violation of Virginia law, shall continue to be lawful, provided that it can be shown by appropriate receipts that such material was installed prior to July 1, 1987.
J. Where a person is convicted within one year of a second or subsequent violation of this section involving the operation of the same vehicle having a tinted or smoked windshield, the court, in addition to any other penalty, may order the person so convicted to remove such tinted or smoked windshield from the vehicle.
K. The provisions of this section shall not apply to law-enforcement vehicles.
L. The provisions of subdivision C 1 of this section shall not apply to sight-seeing carriers as defined in § 46.2-2000 and contract passenger carriers as defined in § 46.2-2000.
(Code 1950, § 46-295; 1958, c. 541, § 46.1-291; 1970, c. 16; 1978, c. 233; 1981, cc. 17, 626; 1985, c. 160; 1987, cc. 298, 315; 1988, c. 751; 1989, c. 727; 1991, cc. 100, 328; 1993, c. 808; 1994, c. 118; 1997, cc. 744, 880; 1998, c. 133; 1999, c. 75; 2004, c. 613.)
GolNat
Nov 27, 2018 03:32 PM
tuvok
South
Nov 4, 2017 02:38 PM
Cam Diaz
Sep 29, 2015 07:17 PM
carid
Sep 28, 2015 10:13 AM
rainman15
Sep 6, 2015 11:10 AM
