OBJECTIVE ONE: Get an S13... Complete!!!!
Old Feb 9, 2005
  #61
PunkingCivic's Avatar
I need TP for my bunghole
Here is something that help with the swap.
SR20DET Swap, SR20DET Install (DVD) Sale price: $24.99
SR20DET Swap and More (Creating an authentic JDM turbocharged monster on a fixed budget, while still staying in school.)
http://www.drifting.com/article.php?...st&show_Title=
scroll to bottom to buy
Old Feb 9, 2005
  #62
S13 SR20DET RedTop
2.0L DOHC Turbo
Turbo Type: T25G
Compressor A/R: 0.80
Injector Size: 370cc
Performance: SR20DET:
Power (ps): 205@ 6000 rpm
Torque (kgm): 28.0@ 4000 rpm
Compression Ratio: 8.5:1
Top Speed:180 Kmh -112 mph
( with speed limiter installed )
Stock Boost: 7 psi
Available in a 5 speed manual, or a 3 Speed Automatic (with OD).
Gear Ratios - Manual Transmission
1st 3.321
2nd 1.902
3rd 1.308
4th 1.000
5th 0.759
Reverse 3.382
Final 4.083
Drive Train: Rear wheel drive, with Open or Viscous Coupling Limited Slip Differentials available.
Diff Ratios:
3.8:1
4.1:1
4.4:1
Old Feb 9, 2005
  #63
SR20DET - S13 Blacktop
Engine Performance:
2.0L DOHC Turbo
Turbo Type: T25G
Power (hp): 205@ 6000 rpm
Torque (ft/lbs): 203 @ 4000 rpm
Top Speed: 180 Km/Hr -112 mph
Stock Boost: 7 psi
Transmission: Available in a 5 speed manual, or a 3 Speed Automatic (with OD)
1st 3.321
2nd 1.902
3rd 1.308
4th 1.000
5th 0.759
Reverse 3.382
Final 4.083
Diff Ratios:
3.8:1
4.1:1
4.4:1
Donor Vehicle:
Old Feb 9, 2005
  #64
Tofast4me's Avatar
Tofast4me is a glorious beacon of lightTofast4me is a glorious beacon of lightTofast4me is a glorious beacon of lightTofast4me is a glorious beacon of lightTofast4me is a glorious beacon of light
PunkingCivic Dude is your car made of carbon fiber?
Old Feb 9, 2005
  #65
_Viper_'s Avatar
Yeah good question lollllll
Old Feb 9, 2005
  #66
NO, if you are looking at my site.
those are just items that will fit the em2 civic that I have pictures for.
I wish my car had all the carbon fiber stuff though.
I have a plain jane silver em2 civic, view my profile for what I have on the ride.
Old Feb 9, 2005
  #67
Lynk's Avatar
punkingcivic listed the s13 engines... i'm either going with s14 or s15...
s15 specs
Cars: JDM 99+ Silvia
1998cc (Turbo T-28)
Horsepower: 247hp@6400rpm
Torque: 203lbs-ft@4800rpm
Compression: 10.0:1
Bore: 86mm
Stroke: 86mm
Transmission: 6 speed manual
Old Feb 9, 2005
  #68
S14 Blacktop
Engine Performance:
2.0L DOHC Turbo
Turbo Type: T28
Compressor A/R: 0.64
Injector Size: 380cc
Power (hp): 220 @ 6000 rpm
Top Speed: 112 mph ( with speed limiter installed )
Stock Boost: 8 psi
Transmission: Available in a 5 speed manual, or a 3 Speed Automatic ( with Overdrive ).
Automatic models are fitted with Power/Hold modes also:
Power Mode - Will allow the transmission to hold gears longer, and will down shift at much lower throttle positions.
Normal Mode - Is an automated sensing mode, if the car feels you are pushing the car, it will use Power mode.
Hold Mode - Will prevent you from pushing the car really hard, and will limit the revs to around 4,000 rpm. A very usefull mode when you desperatley need fuel Hold will also keep it in the selected gear unless you physically select a different gear.
Gear Ratios Manual Transmission
1st 3.321
2nd 1.902
3rd 1.308
4th 1.000
5th .759
Reverse 3.382
Final 4.083
Diff Ratios:
3.8:1
4.1:1
4.4:1
Donor Vehicle:
1994 - 1998 S14 200SX
Suspension and Steering: Four wheel independant suspension is standard on all S14's.
Steering is power rack and pinion, with a turning circle of 9.6m
Wheel Studs: 5
Brakes: Four Pot Ventilated Disk
Weight Distribution: F/R 55/45% using an average driver weight of 60 Kg.
Curb Weight: 2689 lbs
Size Dimensions: Length - Width - Height = 4500 x 1730 x 1295 mm
Wheelbase = 2525 mm
Optional Extras: Sunroof, Velour / Leather Trim, ABS, Limited Slip Differential.
S15 Blacktop
Engine Performance:
2.0L DOHC VVT
Turbo Type: T-28, 60 trim 60 mm BCI-1 compressor in T-04B housing
Injector Size: 480cc
Power (hp): 250 @ 6400 rpm
Compression Ratio: 10.0:1
Top Speed: 180 Km / Hr ( with speed limiter installed )
Stock Boost: 8 psi
Transmission: Available in a 6 Speed manual, or a 3 Speed Automatic ( with Overdrive ).
Gear Ratios
Manual Transmission
1st 3.626
2nd 2.200
3rd 1.541
4th 1.213
5th 1.000
6th 0.767
Reverse 3.437
Final 3.692
Diff Ratios:
3.8:1
4.1:1
4.4:1
Donor Vehicle:
1999 - present S15 200SX
Full electric options, Turbo only. With Helical or Viscous LSD.
Fuel System: ECCS Electronic Fuel Injection ( EFI )
Fuel Tank Capacity: 60 L
Suspension and Steering: Four wheel independant suspension is standard on all S15's.
Optional HICASII 4 Wheel Steering is available too.
Wheel Studs: 5
Brakes: Four Pot Ventilated Disks
Weightings are as follows:
Manual- 1240 Kg
Auto- 1270 Kg
Size Dimensions: Length - Width - Height = 4445 x 1695 x 1285 mm
Wheelbase = 2525 mm
Old Feb 9, 2005
  #69
Here is where I'm getting some of the info
http://www.xatracing.com
Old Feb 9, 2005
  #70
Tofast4me's Avatar
I was looking at "your ride" gallery, not your website. Thats not your car picture with the carbon fiber hood and side panels.
Old Feb 9, 2005
  #71
OH NO! I wish.
I found that doing a google image search
Old Feb 9, 2005
  #72
Tofast4me's Avatar
I don't really like it. I love the carbon fiber hood look just not the side panels. Anyone have the darknight pic of the car made of carbon fiber?
Old Feb 9, 2005
  #73
Tofast4me's Avatar
sorry freddy I'll stop now
Old Feb 9, 2005
  #74
Pharoh's Avatar
Bobaganoosh!
grr...I have one of it but not here or in my gallery.
this is the car at darknights I wish I had bought...hehe.
Old Feb 9, 2005
  #75
EŽik's Avatar
you and me both
Freddy, when do you plan on buying the new engine?? and what locations have you found them in?
Mad Dog Tannen
Sep 12, 2015 12:48 AM
Wiggles
Sep 8, 2015 05:05 PM
thaler4cuse
Sep 7, 2015 08:25 PM
Josh 1973
Sep 7, 2015 10:10 AM
rainman15
Sep 6, 2015 11:10 AM
