FS - Air Ride - Updated PICS!!!
Rep Power: 0 FS - Air Ride - Updated PICS!!!
Almost Brand New Easy Street Air Ride Kit
Includes EVERYTHING you need.
Easy Plug-and-Play Installation.
Sale ALSO includes the Easy Street Auto Pilot Digital Air Management System
***Digital Air Management System is a 1200 USD upgrade which I am including in the Sale. Features of the Digital Air Management System are listed blow. It is a must have when you have air ride ***
Kit Includes:
- Easy Street Auto Pilot Digital Air Management System
- 2 Front 9-way dampening Air Struts
- 2 Rear 9-way dampening Air Struts
- 8 of our 3/8" chrome 300 PSI Valves
- Viair 380C Chrome Compressor
- 5 Gallon D.O.T. Approved Air Tank with 8 1/2" Ports
- 2 200 PSI Dual Needle Gauges with Chrome Bezels
- 40' of 1/2" D.O.T. Approved Air Line
- Nickel plated D.O.T. push to connect fittings
- 145-175 PSI Pressure Switch
- 50' of 1/4" D.O.T. Approved Air Line for your Gauges
- 90' of 16 Gauge Wire for Proper Valve Connections
- Detailed Installation Manual
-One touch ride height
Allows you to return to your ride programmed ride height without tapping switched and watching gauges. Whether your below, or above your height, just tough one button to return to your aligned height.
-Auto ride height on start.
Will lift your vehicle to the programmed ride height with the start of the engine. This feature can be turned
-Individual wheel control
Allows you to adjust each wheel separately. Also known as Front back side to side control.
-All inflate and deflate buttons
Also known as pancake control. Give you 4 wheel height control up and down with one switch.
-Digital Volt Meter
Reads the vehicles voltage to help prolong equipment and battery life.
-Auto leak Detection
Will monitor all 4 corners, if a leak occurs, the system will automatically add air accordingly and warn you of a problem.
-Tuning Feature
Teaches the system the exact requirements to lift each wheel. Ensures that the auto ride height function is perfect every time.
-Only one wire
No more running airlines, power lines, and wiring every switch independently. One wire does it all.
*** Please contact me for shipping costs. I will provide you a quote within 1 day of receiving your PM ***
Asking Price is: $ 2400 CAD including the digital controls
PM me ur email address if ud like sum pictures aswell
Kit Includes:
-Digital Volt Meter
-Tuning Feature
-Only one wire
Rep Power: 0 its basically lifting on its own.... u have to help it a bit
u have a set of $2000 digital controls?
when i said 1200 i wasnt talking bout the whole kit.. i was talkin bout ONLY the digital controls
Rep Power: 238 yo you have air lift bolt on rear struts? an you take a pic of the back top lpate (when you open your trunk) i gotta see how far i gotta screw my screws in... that is, if you still got the kit installed?
Wild Cranker
427
01-28-2016 06:49 PM
7thgensurvivor
38
08-29-2015 11:50 AM
jc33312
05-12-2015 03:17 PM
