Archive - Canada Forsale/Trade eh? Only post here if you have item for sale in Canada and will only sell to someone in Canada. Please start threads with your Province, like this: ON: or AB:
FS: Apex'i Tach
Old 12-18-2003
whitegolf's Avatar
whitegolf is an unknown quantity at this point
Thumbs up FS: Apex'i Tach
Apex'i rpm guages still in box (max) is 12000rpm and is 120mm wide, new conditition asking $250, got pic if anyone interested
This 120mm EL Tachometer features real-time 30-second needle playback, peak-hold, two-stage adjustable warning, and seven-way dimmer adjustments. A'PEX engineers incorporated a 16-bit CPU to provide fast and accurate readings in 1000 step increments. The unit has the capacity to measure up to 12,700 RPM on engines with 1 to 10 cylinders. A'PEX engineers also designed the unit to be thin and compact for installation in tight spaces.
whitegolf is offline
Old 12-19-2003
RW_Blaze's Avatar
RW_Blaze is an unknown quantity at this point
pls send me pics if u have one...
RW_Blaze is offline
bolt-on-bandito
Electrical
32
01-15-2020 03:25 PM
NROD315
09-23-2015 03:46 PM
MamaBear2015
09-15-2015 09:35 PM
sam31444
ECU Fried
07-20-2015 08:31 AM
Quick Reply: FS: Apex'i Tach
