nos 50shot dry system
Old Jun 8, 2003
JLODVO's Avatar
JLODVO is an unknown quantity at this point
hello, ive been hearing a lot that we cant use dry system NOS in our 7th gen civic bcz of the returnless fuel system on our cars? y? pls someone help me on this?? im a newbie and dont want to fry my engine
Old Jun 8, 2003
2001civ's Avatar
2001civ is an unknown quantity at this point
you need the wet kit to get the right fuel ratio with the nitrous the dry kits run to lean. It's just as well the NOS brand in general is ok, but just ok, It's a cheaper cost to you but NX has better quaility. Nitrous works is good as well.
Old Aug 29, 2003
inikkaimar's Avatar
inikkaimar is an unknown quantity at this point
bull **** i just installed my NOS dry kit....it only werks at full throttle....but other then that...its safe...im runnin only 50 shot...jus tap into the intake and u striahgt....jus make sure u know how yur set up werks...
Old Aug 30, 2003
iamboo's Avatar
Retired - SoCal FI Mod
you can run a dry shot, i think 75shot is running a 75 shot dry system...
Old Aug 30, 2003
orso's Avatar
orso is an unknown quantity at this point
needs to be wet. nuf said.
Old Aug 30, 2003
inikkaimar's Avatar
...i jus sprayed last night....50 shot dry....
Old Aug 30, 2003
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
FYI....
You can use either a wet OR a dry system on our cars. Both of them work. The returneless fuel systen has nothing to do with it unless you are going to want to add a fuel pressure regulator/pump...then you would have to convert to a non-returnless fuel system.
Dry systems work ok on our cars. But it would be recommended for you to have something to compensate fuel if you are to be running one. This can be done using a v-afc or if you have a Venom Nitrous System...it should be able to compensate itself because it taps into your stock injectors and "pulses" them accordingly.
NOW...wet systems are probably what people use in order to have more "peace of mind" because they compensate for fuel depending on the size jets that you use. However, it is not guaranteed that the fuel will run evenly across the board.
That is why some people choose to go with DIRECT PORT nitrous systems.
I'm not gonna sit here and go into details of all of these systems. But basically.... JLODVO ....
YES...you can run a dry system on our cars.
SimpleUser
Apr 24, 2021 02:54 AM
mjdiaz89
Jun 21, 2016 09:26 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
hoofboy
Jul 17, 2015 04:27 PM
Hqly2001
22
Jul 12, 2015 06:44 PM
