75 shot with ex manual
Old May 22, 2003
bublik's Avatar
Truehonda.com
bublik is an unknown quantity at this point
I have an 01 ex manual with soon to have upgraded exedy sport/street clutch. I know guys with auto run 75 shot, but can I? Will the longativity of the motor die quickly. I need this car for like 3 more years. I would really like to do 75, that would be awsome!
Old May 23, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
If you can manually retard the ignition timing...not the exhaustt timing, and assuming
you hook everything up correctly, you could be running a 75 shot.
http://www.nitrousexpress.com
Old May 23, 2003
bublik's Avatar
Truehonda.com
hey, that 1/4 mile, did you shoot the n2o off the line? I am going to have just a short ram and nitrous; can I get into the 14's. I am in chicago, so I dont know the sea level here?
Old May 23, 2003
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
HOw much should the timing be retarded?
Old May 23, 2003
dj02's Avatar
-1.5
Old May 23, 2003
SpdRcrChk's Avatar
BOOST JUNKY
Thanks dj02. BTW..gwen rocks.
Old May 23, 2003
bublik's Avatar
Truehonda.com
how long you think motor lasts with 75 shot?
Old May 23, 2003
dj02's Avatar
np and yes she does
75 shot only when u run will not kill ur motor now spraying everyday 75 will cut ur motor life more than half
Old May 30, 2003
75shot's Avatar
I <3 my Evo
75shot should not be trusted
Originally posted by dj02
np and yes she does
whoops
Old May 30, 2003
0903 I Return's Avatar
0903 I Return is an unknown quantity at this point
Originally posted by 75shot
whoops
HA HA
Old Jun 1, 2003
RoadRunner's Avatar
a 75 shot is risky with our motors. i think around a 50 was the safe limit. But i'm sure if you did some internal upgrades, you know pistons, rods it would make the motor last longer. do a search for a nitrous *** it had everything in it
Old Jun 1, 2003
Sivion's Avatar
Resident Tough Guy
Sivion is an unknown quantity at this point
75 shot only when u run will not kill ur motor now spraying everyday 75 will cut ur motor life more than half [/B]
I was under the impression from talking to several people and reading several articles that running ANY Nitrous setup on a car, even if it's the lowest shot available, will tear it apart in just a few executions. Otherwise if I could just run a 50 shot safely using it maybe once in a great while (like at a track run) I would run that setup right now. But I am just afraid of the effects on the engine itself. Anyone know a good article anywhere that would give the true lo down on Nitrous?
Old Jun 4, 2003
02-4dr-civic's Avatar
02-4dr-civic is an unknown quantity at this point
i was running a 60 shot dry NOS system on a 93 Del Sol with a D16Z6 vtec single cam motor and it ran a 14.8 at pomona.... THe main thing you must do is retard the cam gear about 2degrees and also make sure you get a new high flow fuel pump and new fuel presure regulator and boost your fuel up to compensate for the NOS.... without enough fuel your engine will be damaged.....
Old Jun 6, 2003
kjgracing's Avatar
heck no!
NO way! I don't engage the N2O until second gear.
Old Jun 7, 2003
detoX's Avatar
detoX is an unknown quantity at this point
what will happen if dont rettard?
Old Jun 7, 2003
vicLX's Avatar
<--That really is ME
and how do you retard the ignition
Old Jun 9, 2003
Parisdreams's Avatar
Parisdreams is an unknown quantity at this point
about retarding the timing. Check with the manufactor of the kit you buy. Mine say 2 degrees. Retarding you timing is how you compensate for fuel mixture. If you don't listen for the boom, then search for a RSX type S engine and perform a swap. Reinstall your N20 this time either run 50 shot or retard your timing.
AirJordan613
General 7th Gen
Aug 2, 2015 08:55 PM
jessica19699
Jul 29, 2015 05:51 AM
cizsak
Jul 21, 2015 03:39 PM
