K20z3 swap
Old Oct 25, 2021
Bryb's Avatar
Bryb is an unknown quantity at this point
K20z3 swap
Hey my fellow Honda friends! So I知 new here and I am hoping to find some knowledge! I have an 05 civic si hatchback and I知 looking to swap the k20a3 with a k20z3! Can anyone help with a list of parts or accessories I will need to make this happen? Please!!! Thank you in advance!!
Old Oct 25, 2021
Re: K20z3 swap
K to K?
drop it in there.
Contact Hondata to see if tuning ECU needed
Old Oct 25, 2021
Bryb's Avatar
Re: K20z3 swap
Yes a k20a3 to a k20z3
Old Oct 25, 2021
FRSam's Avatar
Click Here
Re: K20z3 swap
You will need an ECU and wiring harness (the A3 has intake side VTEC and the Z3 has both). The rest should be fine as-is.
Old Oct 28, 2021
Bryb's Avatar
Re: K20z3 swap
Thank you! So that will be all I need is an ecu and harness? Can someone tell me where and what ecu I need or should get?
Old Oct 28, 2021
FRSam's Avatar
Click Here
Re: K20z3 swap
An ECU from a later model RSX Type-S would be ideal as that痴 what the engine痴 from. I値l see if I can get the code for it at some point today. Junkyard/Facebook marketplace should have something.
Old Oct 28, 2021
BrotatoChip's Avatar
Super Moderator
Re: K20z3 swap
You could also use your stock ECU but get it Kpro'd, stock harness should work then as well. Kpro costs around $700 but then you have full tuning capability. There may be some sensor changes I can't remember but that would be it.
Old Oct 28, 2021
Bryb's Avatar
Re: K20z3 swap
Ok so another question! What would you do in this case?
Old Oct 28, 2021
FRSam's Avatar
Click Here
Re: K20z3 swap
I guess it depends on what you want. If you池e going to swap, chances are you値l want more power in the future, so K-Pro would be the way to go. If you just want a fun car and not modify any further, ECU and harness should be around half what K-Pro is.
Old Oct 28, 2021
Bryb's Avatar
Re: K20z3 swap
Sounds good! If I did k-pro and didn稚 do any mods in the future is it a waste of money? Technically the same as a stock ecu at that point?
Old Oct 28, 2021
Super Moderator
Re: K20z3 swap
You would load a stock cal for the z3 onto your ECU and just run that. You could consider it a waste of money if you don't do any more upgrades in the future.
Old Oct 28, 2021
FRSam's Avatar
Click Here
Re: K20z3 swap
Forgot the Z3 came in the Civic Si as well.
https://www.ebay.com/itm/31363173254...sAAOSwXylhBW46
https://www.ebay.com/itm/254453566948
This should be all you need, assuming the K20Z3 is complete.
Old Oct 28, 2021
Super Moderator
Re: K20z3 swap
Would also need an adapter harness or some custom wiring for the body connections. z3 had a 6 speed with reverse lockout and the high frequency VSS, your EP3 doesn't have either. May see faults for reverse lockout, would need some sort of VSS converter. Or were you taking the 6 speed transmission too?
Old Oct 28, 2021
Bryb's Avatar
Re: K20z3 swap
I was gonna keep my 5 speed for now
Old Oct 28, 2021
Bryb's Avatar
Re: K20z3 swap
I can just buy adapter harness? Would k-pro eliminate the need for all that?
Old Oct 28, 2021
Bryb's Avatar
Re: K20z3 swap
The z3 is complete
Old Oct 28, 2021
Re: K20z3 swap
call them
they handle more cars than any of us
share results for the community later on
Old Oct 28, 2021
Bryb's Avatar
Re: K20z3 swap
I値l give them a call! Stay tuned!!
Old Oct 29, 2021
Super Moderator
Re: K20z3 swap
I was also going to suggest contacting Kpro (Hondata). I believe once your stock ECU is Kpro'd you keep the original engine harness and transfer to the new engine. No additional wiring is needed unless some of the sensors need swapped or rewired. You can also ask if there's a stock z3 calibration available in the Kmanager software for your stock ECU.
HuskyPlneyLaski
Engine Swaps
Oct 12, 2021 01:11 PM
Philip0226
Engine Swaps
Apr 15, 2018 10:51 AM
SevenCyrus
May 10, 2005 01:25 AM
CivicMexicano
Texas
Feb 3, 2004 07:26 PM
