EM2 K20 Swap (Help)
Old Apr 27, 2020
  #31
FRSam's Avatar
Click Here
Re: EM2 K20 Swap (Help)
No it isn't. I've been using the stock EM2 shifter with an RSX Type S 6 speed transmission without any issues. RSX cables are needed but not the shifter itself.
My bad, I misread the list thinking it was the entire assembly
Edit: The list I was looking at actually says it requires the shifter assembly but you've done it so obviously you know.
Old Apr 27, 2020
  #32
GroovyJay's Avatar
GroovyJay is an unknown quantity at this point
reverse lock out not needed ?
Old Apr 27, 2020
  #33
Colin42's Avatar
Just remember to not shift into reverse unless stopped
Old Apr 28, 2020
  #34
GroovyJay's Avatar
well guys its finally coming together appreciate all of your help, I finally have all the parts! I Will send in my ECU as soon as they open at HONDATA hopefully soon. My Last question that just seems impossible to find is do you guys know the thread pattern of the OEM bolts in the engine bay, Idk if they are 10x1.25 or 10x1.50? I Really Appreciate all of your Communication, was extremely helpful!
Old Apr 29, 2020
  #35
BrotatoChip's Avatar
Super Moderator
Found this on the Honda-tech forum:
M6-1.0 --- common (most of our 10mm head bolts)
M8-1.25 -- common (probably most of our 12mm head bolts)
M10-1.25 - some headbolts) (probably most of our 14mm head bolts)
M11-1.25 - freakshow timing belt tensioner on H/F engines. 7/16-20 is VERY close.
M11x1.5 -- some headbolts)
M12x1.0 -- flywheel bolts + shift fork ball spring bolts)
M12-1.25 - common (probably most of our 17mm head bolts)
M12-1.5 -- lugnuts)
M14-1.25 - crank bolt?)
M14-1.5 -- oil pan drain plug. 19mm head bolt that connects rear trans bracket to trans
M16-???
M20x1.0 -- 10mm allen bolt
M20x1.5 (oil filter threads????)
M22x??? d-series countershaft nut
M28x1.5 - 14mm allen bolt
Old May 9, 2020
  #36
GroovyJay's Avatar
Hey Guys, So I got the ESK3 Hasport Mounts, And Ive seen some videos and they usually have instructions included.. Mine did not does anyone have any information they can spare?
Old May 9, 2020
  #37
Colin42's Avatar
Go to the manufacturer's website?
Old May 10, 2020
  #38
GroovyJay's Avatar
I did it was not much help, I installed the trans and engine mounts by just matching holes lol
but I have one more mount im assuming it mounts to the sub frame
Old May 11, 2020
  #39
Super Moderator
Pic? If you figured out the driver and passenger side mounts the last one should be for the front into the subframe mount.
Old May 21, 2020
  #40
GroovyJay's Avatar
I did figure out the mounts, although I did not know the em2 was one of the most difficult swaps in terms of information ...
what did y'all do about the gauge cluster since obviously its gonna be redlining higher ?
Old May 21, 2020
  #41
Colin42's Avatar
I think the RSX cluster swaps in, not sure if any wires need to be changed
Old May 22, 2020
  #42
Super Moderator
What are you talking about, there is tons of information. There's a .PDF showing you how to swap along with multiple threads of different forums.
You don't have to do anything really. The stock cluster will still go up to 8k you just won't see where redline is. The RSX cluster can be swapped in but it has different wiring/connectors, different mounting points, and the trim piece to make it look original won't fit either. I kept the stock one for a while, after maybe a year I swapped to the RSX cluster, now I want to create a custom LCD screen to use.
Old May 26, 2020
  #43
GroovyJay's Avatar
I Read Through the PDF And Im Not very savvy with with my car or swaps to know immediately where anything is supposed to go is supposed to go, But I got as far as I did I have my engine in.. but not married to the tranny Yet. The tranny mount is on the tranny, the bracket for it like shown in the PDF on pages 14-15 are identical to mine as well as the passenger side where the engine is, is already mounted (HASPORT). It explains the rear mount on page 17 but I AM confused as to how it should fit. IDK yet because my tranny isn't in but I just feel its too low unless im missing a bracket or if the bracket from the OLD subframe is supposed to transfer to the new one.
Old May 27, 2020
  #44
Super Moderator
I can't find a good picture but here's what the rear mount looks like, it consists of two pieces.
Reference number 6 bolts onto the engine/trans. Bolt number 11 goes through a hole on the transmission end of the block just above where the transmission mounts. The two bolts with reference 12 bolt into the transmission on the diff section. The second piece is reference number 2, it bolts to the subframe and then a single bolt attaches it to the other mount piece. The mount kit only comes with reference piece number 2. It is an OEM replacement piece that is stiffer. I couldn't stand how much vibration there was in the cabin after my swap so I removed the front and rear mounts and replaced them with stock RSX ones.
Old May 29, 2020
  #45
GroovyJay's Avatar
Wow Thanks! The Best Help. That Makes A lot More Sense. You Think That 6 piece from the non Si subframe is the same?
Old Jun 1, 2020
  #46
Super Moderator
No. The Si is the only 7th gen Civic that has the K series in it. The Si or RSX are your only options here.
Old Jul 5, 2020
  #47
Brian8900's Avatar
Brian8900 is an unknown quantity at this point
I have a K20a2 in my '02 EX. Feel free to ask questions.
What did you do about the fan switch? Do I reuse the d17 switch and wire the fans to that and then run a wire to the fuse box?
Old Jul 13, 2020
  #48
Super Moderator
I used the EP3 radiator with the fan switch in the bottom. I wired one side to ground and the other to the fuse box. I don't see any mention in the Xproductionz.pdf, I must have read that somewhere on this site.
Old Jul 26, 2020
  #49
Santiago Reyes's Avatar
Santiago Reyes is an unknown quantity at this point
what ecu and harness did you use can i just use a regular rsx ecu and harness?
Old Jul 27, 2020
  #50
piano55man's Avatar
piano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of light
I used an experimental ecu setup...
07 Element MT with a special harness adapter.
it had the Ktuner board wired into the ECU.
Old Jul 31, 2020
  #51
Super Moderator
I used RSX type S ECU and matching harness.
Old Aug 9, 2020
  #52
Rednex13's Avatar
Rednex13 is an unknown quantity at this point
I’m sure you guys have been asked this a lot but I just purchased an 04 RSX type S to use as a donor for my swap with my EM2. Everything up front is still in tact but I’m unsure what harness I’d need to get to make it as easy as possible. All the online stores want to sell you the world and I’m pretty sure I don’t think I need a 4K purchase when I want a basic swap for now.
Thanks in advance
Old Aug 9, 2020
  #53
FRSam's Avatar
Click Here
Literally the comment before yours.
Old Aug 9, 2020
  #54
Rednex13's Avatar
I seen that but I’m just wondering if I need to purchase one from hybrid to hook up to everything in my dash. I guess that would be like a conversion harness.
Old Aug 9, 2020
  #55
Rednex13's Avatar
I know it might be a dumb question but I’m used to working on heavy equipment and my buddy that is helping me is a military mechanic so it’s a bit different than a tank!
Old Aug 9, 2020
  #56
FRSam's Avatar
Click Here
It'd certainly make the process easier. I'd do it for the sake of a couple hundred bucks. Small number when considering the total budget.
File Type: pdf
Old Aug 10, 2020
  #57
Super Moderator
You can either use a conversion harness or repin a connector. It's all specified in the .pdf Chezboat posted.
Old Jun 26, 2021
  #58
gspd.5502's Avatar
gspd.5502 is an unknown quantity at this point
The WireWhere.com cluster conversion might be a good option.
Old Jun 26, 2021
  #59
gspd.5502's Avatar
Or you could save a couple bucks and use this harness...
Old Jun 26, 2021
  #60
gspd.5502's Avatar
The WireWhere.com LCD gauge conversion would be a good option. If you're running Kpro B4 that is.
Aquiles whip
Texas
Apr 21, 2009 07:24 AM
streetthrowback
Engine Swaps
Oct 20, 2007 07:30 AM
bbeboi
Nov 17, 2006 12:30 PM
allshownogo01
Engine Swaps
Mar 6, 2006 09:40 PM
DrivenConcepts
Engine Swaps
Apr 14, 2005 11:41 PM
