K20a series swap question
Old Nov 23, 2015
demigodrva's Avatar
demigodrva is an unknown quantity at this point
Ok. Short version is I'm looking for a another engine for my 05 civic si. I was told the tapping in my engine was a risk(spelling?) pin was worn. It sounds like it finally went the other day. Went from tapping to rattling/grinding sound. Car was still drivable when I parked it. Definitely not driving it anywhere now, but it does start and would go. Just not sure how far.
I been looking at replacing the stock k20a3 with another, but looking at pricing, I'm debating on k20a2 or k20a swap. I have no plans on really enhancing the engine, but the added power from the stock a3 to either of these seems worth the price. I've read several swaps. Some say it's a direct bolt on swap nothing else needed, some need other parts. Car is my DD, looking to get her back on the road quick and cheap. Any info is greatly appreciated.
Old Nov 23, 2015
Re: K20a series swap question
5 k should be a good number as long as you can get a cheap one sourced
lots of parts, including ECU/wiring/etc
Old Nov 23, 2015
mac25's Avatar
Dr Krieger of Modification
"pin" as in piston pin?
if so
Why not rebuild the block, piston heads, rings, rods and seals
then do a head swap?
It should cost far less, especially if you are doing it your self.
Old Nov 24, 2015
demigodrva's Avatar
if so
I found a k20a3 motor w/auto tranny, ecu and harness, all for $550. 69,000mi. It's out of a 06 rsx. Should be a straight swap correct. Something about the manifold being different I think I read, as to why the torque is slightly higher. Is the tranny, ecu and harness needed?
Old Nov 24, 2015
Ouch, just saw you have an Si and you are in U.S. (Canadian So is the U.S. EX)
Much less involved, yes.
Old Nov 25, 2015
mac25's Avatar
***I could be wrong on this but im pretty sure...***
...if your original head has vtec then it should be a straight swap.
Old Nov 28, 2015
PMI's Avatar
PMI
PMI has a spectacular aura aboutPMI has a spectacular aura about
Originally Posted by demigodrva
...I was told the tapping in my engine was a risk(spelling?) pin was worn. It sounds like it finally went the other day. Went from tapping to rattling/grinding sound....
Piston "wrist" pin:
I would get a second opinion. Wrist pins and rod bearings normally go from tapping, to knocking, to a broken engine. Rattling grinding sounds more like something else.
Rod knock is a pretty characteristic sound to a mechanic, lots of examples on youtube, too.
ShaggySi
Jan 2, 2016 01:56 PM
steve6
Nov 22, 2015 08:18 PM
Kkoestner
Nov 22, 2015 04:50 PM
don15coupe
Nov 18, 2015 02:04 PM
rollaguy
Suspension
Nov 11, 2015 07:48 PM
