Non VTEC to VTEC head swap
Old May 5, 2014
Metalzone's Avatar
Metalzone is an unknown quantity at this point
I have a Honda Civic 04 LX
I want to swap a head with VTEC
Do any of you guys know what would be the necessary parts that I would need to get?
Thanks
Old May 5, 2014
SeAmUs_MaCk's Avatar
SOHC Enthusiast
SeAmUs_MaCk will become famous soon enough
Re: Non VTEC to VTEC head swap
Okay so I'm going to assume you have an D17A1 in your 04 Civic. What you need is an D17A2 Head, which came on the US EX Model. You will also need an EX ECU...When you get an A2 head...make sure to get the VTEC Solenoid......
Now...Intake Manifold, Throttle Body, Fuel Rail, Injectors, Etc. I'm not sure how different they are compared to the LX model that you have. I know D16's have different IM & TB....but not sure about the D17's....btw you can google all this stuff....
Try a search next time.... I'm just in a good mood. For instance I know that the d16y7 injectors are different cc then the y8 injectors. You have to do your research....It's not as simple as slapping a A2 head on and your good to go....(Well if you want VTEC to work)
You are also going to want a new head gasket, and since you have it off anyway (and if you don't plan on turbocharging it) Get some ARP head Bolts...If you think you may turbo down the road, get Head Studs. If you are asking a question as general as this though, I would hope that you aren't going to do this swap by yourself. Have someone help you that knows about Hondas...(there are lots of us out there) You are going to need to run a wire from the VTEC solenoid to the ECU, and i think from the IACV as well (Not sure if you have to make it a 2-3 wire switch...not sure about the d17's) There also maybe be an oil jet plug in the block between cylinder 2 & 3..... Maybe someone else can elaborate. But....good luck
Old May 5, 2014
seamus mack,
he posted on the wrong section, he have a 7th gen... I will move this to right section...
dbagaus
SOHC D17Ax non-VTEC - VTEC Engine Swaps
70
Feb 22, 2023 04:26 PM
tadr88
Jun 8, 2015 12:28 AM
01civyv3
Jun 2, 2015 05:21 AM
codys civic
May 31, 2015 03:28 AM
TonnyHegger
Jan 22, 2002 08:14 PM
