98 Civic EX.............B18c Engine Swap!!!!!
Old Dec 4, 2013
SayItAintTony's Avatar
SayItAintTony is an unknown quantity at this point
So I came to the conclusion that I want to swap out my D16Y8 for a B18c. I don't know much about engine swaps. If anyone can tell me what i would need to make this swap possible, I would really appreciate it. I would also like to know if it will be a pain in the ***? Thanks!!
Old Dec 5, 2013
mac25's Avatar
Dr Krieger of Modification
Re: 98 Civic EX.............B18c Engine Swap!!!!!
since you don't know much about engine swaps It will probably be a pain in the ***.
I've only worked on D16s and D17s so I can't give you exact info but I'll give you a few topics to check up on and most of them should be in the search function.
you'll need to know if the stock wiring harness and ecu are both used in the two engines. If the ECU's are different then you'l have to see if you can stll use the stock wiring harness or if that will have to be replaced.
you'll have to see if the stock engine mounts will hold the B series. if not then can you use B series mounts in the engine bay for your D series or will you need custom/aftermarket mounts?
Will the stock drive shafts/brakes assembly mount to your stock suspension?
will you need a more aggressive cooling system for the DOHC engine?
will you need to swap out your sub frame?
Old Dec 10, 2013
MC_d16's Avatar
MC_d16 is an unknown quantity at this point
Here are some stickies to read. They really helped me out!
Engine codes - To read, not to ask, Honda swap 101 Chassis code?
Shout out to sdaidoji for sending these to me!
Old Dec 10, 2013
thanks for the links MC_d16 , i will check them out.
Old Dec 11, 2013
Fliptard's Avatar
Fliptard will become famous soon enoughFliptard will become famous soon enough
You Need the following:
B series motor, trans Complete
B series mounts for EK
B series header
B series shift linkage
B series axles
Correct ECU for engine
B series rad hoses for EK
All Above ^^^ can also be found/bought for a 99-00 SI civic as it came equipped factory with a B16a2, except ECU and distributor, which is an OBD2B ecu. Jumper harness from OBD2a chassis to OBD2b ECU could be used if using this ECU and running OBD2, and OBD2a harness to OBD2b distributor.
Jumper harness for OBD2a Chassis to OBD1 ECU and OBD2a Harness to OBD1 distributor ( ONLY IF RUNNING OBD1)
The engine harness will plug and play, a couple sensors might need to be extended to reach the plugs on the B series motor.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
usajags84
May 10, 2015 08:11 AM
ashleymmackey
Apr 18, 2015 09:48 PM
shawe90
Apr 14, 2015 07:10 PM
