R18 ECU swap for D17?
Old May 16, 2013
Tragedy's Avatar
skate or die
Would this ecu swap work? Why not if no?
Had a random thought, wondered if anyone can swap the d17 ecu for the r18's ecu. Similar engines, some differences, but... the r18 ecu can accept flash pro...
Old May 16, 2013
Re: R18 ECU swap for D17?
Short answer would be no IMHO.
The engines are only similar in that they are both 4 cylinder engines.
The wiring is all completely different.
Cam/crank signals are probably different,
and the PCM is programmed to meet different and newer EPA regs than older units, that means more and different emissions crap on the cars.
Does aftermarket support custom reprogramming for a stock PCM?
06 and newer use this type of PCM connection:
I'd say to just buy a programmable ECM that will fit your car. Probably much simpler.
Old Nov 1, 2013
nsrhonda89's Avatar
nsrhonda89 has a spectacular aura aboutnsrhonda89 has a spectacular aura about
According to Honda data you can use one of these ECU in your car.
ECUs for the D17 may be sourced from the following vehicles
  • 2002-2004 RSX Base 5 speed (PND -A0 ECU)
  • 2002-2004 RSX Type S 6 speed (PRB-A0 - ECU)
  • 2002-2004 CRV 5 speed (PPA-A0 ECU)
  • 2002-2005 Japanese DC5 Integra Type R (PRC ECU)
  • 2003-2005 Japanese Civic Type R (PRD ECU)
  • 2002-2005 Civic Si (PNF ECU)
http://www.hondata.com/kpro_d17.html
Dameancharles
Engine Management
May 13, 2019 07:10 AM
krarnold
Mar 10, 2010 10:01 AM
RAZRBLD
Apr 27, 2007 02:01 PM
04D17
Oct 18, 2006 03:46 PM
Marcus
Bolt-on Engine Performance
Mar 31, 2005 04:35 PM
