01 Civic LX Trans bits the dust
Old Jun 12, 2012
sdaugh7261's Avatar
sdaugh7261 is an unknown quantity at this point
Got a 2001 honda civic lx with a 4 speed auto, the trans just went out on it and I can't find a replacement anywhere near Tacoma. I don't wanna spend more that $400 for it and have a friend that can swap it. But I have no clue wtf the transmission model is....at lease with my ford I know its a AOD whatever model.
Old Jun 12, 2012
Re: 01 Civic LX Trans bits the dust
http://www.car-part.com/
Only $400? Good luck.
HTH
Old Jun 13, 2012
sdaugh7261's Avatar
That does help alot, now I just need a DYI with pics on how to do the auto transmission swap.
Old Jun 13, 2012
Did you run off all your help already?
LOL
Old Jun 13, 2012
sdaugh7261's Avatar
LOL
Just in case he dares to say, I have 3 bolts left over I can pull out a manual and say "THE **** YOU DO, THEY GO HERE!!!"
Old Jun 13, 2012
Ummm, I don't think the manual works the way you think it should here.
Old Jun 13, 2012
sdaugh7261's Avatar
I do not think the answer you gave means what you think it means. and before you can say it. Inconceivable
Old Jun 13, 2012
It made perfect sense in MY head. LOL
If I yank 3 random bolts out of the car during a trans job and toss them on the ground, YOU ain't going to figure out where they came from by using a shop manual.
Old Jun 13, 2012
sdaugh7261's Avatar
So...drain the coolant and atf, unbolt the battery and starter, jack up the trans, unbolt it from the engine and mounts and drop it out. Pretty much?
Old Jun 13, 2012
Umm, what does your shop manual say about this?
Go ahead and look it up, I'll wait.
Hint: You missed a few things.
The car has a subframe that needs to come out. The steering rack stays attached to the subframe.
You will need to rig up something to keep the engine from dangling out while the subframe and trans are out.
Why coolant? I do not drain the coolant. No need.
Why bother draining the ATF if the trans is junk? Ok, I would anyway.
Most trans failures send debris all throughout the system.
You REALLY need to be able to power flush the trans cooler inside the radiator. A factory reman trans would come with an inline filter to install in the cooler lines to protect the new trans.
Any trapped debris could come out of the cooler and ruin a fresh trans in a matter of seconds. Good luck getting that covered under warranty.
You might talk to the dealer guys about bringing in your radiator (pull it out and carry it in) and having them flush the trans cooler in it. We have a nice loud machine that uses hot fluid and pulsation and pressure to purge the cooler.
Or talk to a trans shop about flushing it out.
I'm not 100% sold on the aerosol spray cans that some people use for flushing the coolers, but it would be better than nothing.
HTH
Old Jun 13, 2012
sdaugh7261's Avatar
Can I get this done in a day?
Old Jun 13, 2012
*I* can. I have everything necessary to do the complete job in a timely manner at my disposal. I do this for a living though.
I have no idea if YOU can.
Sorry.
bsmiley
Apr 27, 2015 01:27 PM
inarschenk
South
Apr 18, 2015 04:29 PM
jackoncruzpr
Apr 16, 2015 12:29 PM
NukEX
Nov 9, 2001 09:21 PM
CiViCPrAnInG2k1
Nov 2, 2001 02:49 PM
