2003 EP3 Jdm k20 Swap Help
Old Apr 22, 2012
ellis_zach's Avatar
ellis_zach is an unknown quantity at this point
Hey new to the forum and just bought a 2003 honda sir (si in the USA i believe) with 153,000kms on it. Ive done a b16 swap in a del sol and owned a s2000 so ive been in the honda scene for a bit.
Im wanting to swap a jdm dc5 type r engine into it and just wondering how hard it would be and if anyone has done it? I amagine the engine mounts are all the same but how would the shift linkage all work?
Would love to get some info from people that have done it or if theres a forum about it around
Old Apr 23, 2012
DA9_GSR's Avatar
DA9_GSR has a spectacular aura aboutDA9_GSR has a spectacular aura about
Re: 2003 EP3 Jdm k20 Swap Help
I did a JDM EP3 K20A swap on my 2003 SiR. It was really easy. I needed the JDM EP3 front sway bar in order to use the JDM K20A exhaust manifold and catalytic converter. You should consider getting a JDM DC5 ITR or better center pipe. EP3 center pipe is tiny and restrictive. I did not have to notch my shift box in order to get into reverse. Make sure your swap comes with complete engine harness UNCUT. That way you can have reverse lockout working properly.
All in all, it's a pretty straight forward swap. You're swapping a K for a K. No modifications needed.
Good luck. Awesome powertrain. Worth every penny.
Old Apr 23, 2012
ellis_zach's Avatar
Thanks alot for that info. Ill be doing as much research as i can on it in the next couple months and hopefully get this progect going. Any info is helpful.
How did the power gain feel? Did you tune it with kpro?
Old Apr 23, 2012
DA9_GSR's Avatar
The difference was amazing! The LSD was the most shocking difference. You can feel it work while accelerating out of a hard cornering manoeuver. Also the gearing is incrediblty short compared to the OEM transmission. I do not have Kpro yet. I wouldn't mind spending on that upgrade. Looks like it can yield some pretty good gains.
fatih717171
Jul 25, 2016 06:22 PM
BootyDo
Jun 21, 2016 03:45 PM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
fatih717171
Jul 8, 2015 12:14 AM
