Godspeed Turbo Kit
Rep Power: 0 Godspeed Turbo Kit
Hello 7th Gen's,
Jum... A GodSpeed turbo kit for almost $1000.00. Leaving everything stock, and just 3 to 4 psi. What are we looking at ??? Is it worth the money if for just 3 to 4 psi. ??? How responsive will our car be, with just this "simple" modification???
Cheers,
Cheers,
Live for the Twisties
Rep Power: 261 Re: Godspeed Turbo Kit
Still need k-pro, which is $1000.. tuning.. $300ish... and you'll probably only make 150whp at 3-4 psi. I'd rather just run a stage 2 cam.
You Stay Classy, San Diego
godspeed kit uses knockoff components of everything. Just a word of advice do it right. BUy real brand name stuff when it comes to turbos. It will save headaches in the end. Most important things not to cheap out on are blow off valve, wastegate, turbo, and engine management. For engine management kpro will be the easiest option. It comes preloaded with a map for up to 6psi safely with rsx-s injectors. Godspeed kit should hold up okay just realize that there's a reason why it's so cheap. They cut corners somewhere.
Hutch1051
09-29-2015 09:20 AM
