Motor swap to d17a2
Motor swap to d17a2
Ok so I just got a d17a2 motor from an 04 civic to put in my 02 civic dx besides changing the wiring harness and ecu is there anything else I need to do I have been reading through all the forums and I just want to make sure
Re: Motor swap to d17a2
But when I got the motor it came with an auto wiring harness that I'm trying to get rid of I need the 5spd one if you know anyone that has one to sell or trade
I don't see why not.
Are you gonna swap to an ex exhaust setup? or are you gonna keep the dx/lx setup? If you stick with the dx/lx setup, you may need to extend the O2 sensor wiring, too.. Or at least get O2 sensor extension harnesses
I cracked the block an just wanted to go to the vtec way I got the motor with a wiring harness for 550 but auto harness but also more upgrades I can do with the vtec head got a cam for it to already
Does anyone have instructions to extend the 02 sensor wiring, or how to get a hold of an extension harness?
I have an 02 LX, 5spd. The previous owner dropped in a d17a2 from an EX, including the EX harness (looks like it was from an AT, which is different from the MT harness). Some of the wiring came loose for the secondary 02 sensor and I'm having a hard time matching up the wires.
Check the thread above bud. I've done this swap and kept it simple. Pm me if you have questions
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
jmdcivic
May 20, 2015 09:52 PM
Supramk3
May 11, 2015 07:55 PM
