recommended engine swap for 2001 Ex
I know a little bit bout mechanics, and I'm taking some classes to maybe choose as a career, but I'm still a newbie.
My engine is leaking by the oil pan & the bolts that hold motor down. I figure why repair an old 110K motor, instead get a newer one.
It's a project car that I want to fully deck out; inside & out.
So what are some good motor models as far as performance compared to around a $5,000 budget?
Re: recommended engine swap for 2001 Ex
SEARCH. please and thank you.
https://www.civicforums.com/forums/7...-question.html
https://www.civicforums.com/forums/7...lp-needed.html
https://www.civicforums.com/forums/1...nsmission.html
https://www.civicforums.com/forums/3...gine-help.html
https://www.civicforums.com/forums/1...t-7th-gen.html
https://www.civicforums.com/forums/7...s-angeles.html
https://www.civicforums.com/forums/1...uild-swap.html
https://www.civicforums.com/forums/7...ming-soon.html
https://www.civicforums.com/forums/7...gine-swap.html
https://www.civicforums.com/forums/1...rid-civic.html
https://www.civicforums.com/forums/6...dohc-help.html
Live for the Twisties
You could swap in a k20a3 for $5000, thats the only engine swap that fits in your budget and you'd need to do all the labour yourself or it would be closer to $6000.
oh yea, forgot about the other f20's
still, fact remains.. gotta spend hella to make it fit and work in an es1/em2 chassis
What would be a good combo for k20a3 lk for the head? I don't understand when ppl on other posts say they get a certain block w different head, how could I insure the fit. And if I order it online would I need the computer for it n what other main thing
Here's a basic idea of what you need to do the swap, http://xproductionz.com/k20swap/k20swap.html
Head swaps start to get complicated. Many people swap a k20a2 head onto the k20a3 block, then upgrade the rods and add hondata to make it run right.
k20a3 motor doesnt have real vtec. it was made to be a gas saver. vtec kicks in at 2200 rpm with that motor. and k20z3 is alright but getting a k20a2 is a better motor to get just cause its cheaper and puts around the same power down.
I rather buy a $500 k20a3 and put $2000 worth of mods into it, than spend $2500 on a k20a2.
cloudguy
Apr 28, 2015 05:02 AM
