2003 Civic Automatic Turbo?
Old Jul 22, 2010
neojamal747's Avatar
neojamal747 is an unknown quantity at this point
I have a 2003 Civic EX coupe that already has everything that could possibly be bolted on...CAI, Cat back exhaust, and headers. I am looking for more power though. A transmission swap will be way too expensive but a easy turbo kit off of ebay would be possible. They are around 500 to 1000 dollars.
Is this a good idea or bad? and if its a good idea what kit is should i go with? And are Performance Chips a easy power gain?
Thanks for answering in advance!
http://cgi.ebay.com/ebaymotors/63-T3...ht_6318wt_1164
Old Jul 22, 2010
02civicsi02's Avatar
Low and slow!
Re: 2003 Civic Automatic Turbo?
Lol.
Old Jul 22, 2010
tjg312's Avatar
tjg312 is an unknown quantity at this point
nah sorry man.. i also have an '03 auto and from what i've read and researched, it's a bad idea, especially if youre looking for an ebay turbo.
you're better off just running nitrous, and as long as you do it safely you'll be fine
Old Jul 22, 2010
bad idea. the factory trans can barely handle the 90whp from the engine without turbo.
Old Jul 23, 2010
jamis33's Avatar
You Stay Classy, San Diego
turbo on auto tranny will work as long as you have a transmission cooler. there was a guy that was running like 170whp or something for quite a while with no problems. you need pcs xfc to get it to work properly tho.
Old Jul 25, 2010
mac25's Avatar
Dr Krieger of Modification
i know everyone says stay away from e-bay turbos. but why? i mean if the turbo blows out from bad design won't you're moded ecu just take the new air fuel readings of the now none turbo system and let you drive "stock"? if so then you're only down $1000 plus shipping from e-bay, if it works then you save $5000 from buying namebrand. or am i way wrong and a broken turbo would f up you're timing so bad that the car wouldn't recover?
Old Jul 25, 2010
Mad Dog Tannen's Avatar
Ebay turbos will crap out very quickly, they are chinese garbage. I had one on my eclipse. Don't waste your money. You also have to buy fuel, pump injectors, ECU mod. The blown turbo could come apart and metal bits could eat up your engine. Plus you cannot run very much boost on stock internals anyway. I agree with tjg312, a good wet nitrous setup is a much better use of $1000 dollars. Save the turbo for if/when you rebuild your engine with forged internals.
Old Jul 25, 2010
Low and slow!
They say that cause they are crap. You get what you pay for and its nothing but crap. They dont last very long and the tune has to be perfect. And only some ecu's can run off of just new air fuel readings. I know some if the weather is like 3 degrees hotter or colder then you have to retune. Kpro is one of the ecu's that can run off new air fuel readings cause all kpro does is run off the stock ecu. Like the stock ecu was made if anything changes in the air fuel or anything it adapts to it and changes. Turbo is not something you just slap on. The tuning is the most important part. And with ebay turbos that are made from crap it has to be perfect.
Old Jul 25, 2010
VTEC-4.0's Avatar
Don't do it.If you want a turbo,get a real one like Greddy or something,but don't put it on that automatic.Gonna ruin your transmission.
Poopies
Apr 20, 2017 11:36 PM
usajags84
May 10, 2015 08:11 AM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
Fastfebur
Apr 22, 2015 01:37 PM
deus-ex
Apr 13, 2015 12:29 PM
