Tuning
Re: Tuning
You need higher output injectors.. The injector rate depends on what your goals are. You may also wanna get a higher output fuel pump (I.e. Walbro 255lph). As for engine management, k-pro.. But you need a donor rsx ecu + the 1175 for the k-pro.
You should read my massive post on this thread (post #6)
https://www.civicforums.com/forums/1...urbo-help.html
Re: Tuning
Re: Tuning
oh mother bitch.. I forgot to click "post quick reply" before i closed the tab.. bah.. lol
RSX-S injectors work for low-ish boost levels. I'm not sure how high of boost you can go, but a tuner may be able to tell you.. It bumps the injection rate from 215 to 310cc/min (or something like that). I hear SRT-4 injectors work well, too.. I'm not sure what the flowrate on those are. Dezod.com also sells Deatschwerks 480 and 525cc/min injectors.
beanhead
Sep 24, 2015 12:04 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
