help turbo install
Old Apr 17, 2010
snoman's Avatar
snoman is an unknown quantity at this point
help turbo install
hey guys running into a little bit of trouble. i have an 02 civic lx 5 speed i just installed the TSI turbo kit into it, and have 410cc injectors and the AEM FIC for tuning. after installing the kit and turning on the car with the AEM set with stock settings the car just starts reving up to 3k rpms and never idles down. I do have some exhaust leaks that are going to be fixed at the exhaust shop tomorrow and i plan to get the car tuned before i drive it around or get on it i just need to drive it to the tuner. any ideas why the car wont idle? should it have this much trouble idling? also the car seems to be burning alot of oil. and ideas?
Old Apr 17, 2010
sureshot1979's Avatar
sureshot1979 is an unknown quantity at this point
Re: help turbo install
yeah well it sound slike your iac is clogged check that and did you up grade the fuel pump
Old Apr 17, 2010
need more info so you can get the right answers
Old Apr 17, 2010
410ccs is alot of gas to be runnig the stock fuel pump
walbro makes a good pump for a hundred bucks
Old Apr 17, 2010
also get HONDATA S300
Old Apr 17, 2010
WHAT PLUGS are you running,what oil,what engine,what fuel,
any thing on the map sensor like a missing link by synapse, man alot could be wrong
Old Apr 17, 2010
snoman's Avatar
fuel pump is stock but i do plan on changing it. the plugs bosch iridiums one step colder, gas is 93, and i havent done anything to the map yet.
Old Apr 17, 2010
snoman's Avatar
o and the engine is a d17a1
Old Apr 17, 2010
01civicbullet's Avatar
01civicbullet is an unknown quantity at this point
hey, i also have a d17a1 in my 01 civic dx. ive been looking for a turbo kit for months now and i cannot find one. what turbo kit did you use and where can i find one?
Old Apr 17, 2010
[QUOTE=01civicbullet;4466350]hey, i also have a d17a1 in my 01 civic dx. ive been looking for a turbo kit for months now and i cannot find one. what turbo kit did you use and where can i find one? or is there a universal kit out there tht will work. i do have a few mods already like headers,aem cold air intake, and catback exhaust but i want a little more hp.
Old Apr 17, 2010
snoman's Avatar
ok figured it out, it was a leak i must have passed over. got the car dynoed today it made 186whp on 6-7lbs. plan on taking it easy for the next week or two until i get a new fuel pump. thanks for all the help guys
Old Apr 17, 2010
HLC's Avatar
HLC
HLC is an unknown quantity at this point
wow nice, 186whp on 7psi is good. post up some pics. i wanna see the bay.
Old Apr 18, 2010
2004GraphEx's Avatar
2004GraphEx is an unknown quantity at this point
[QUOTE=01civicbullet;4466353]
www.procivic.com
go there and on he right side of the screen input the info about your car and you will look at everything that fits it and the turbo should be there. i have the d17a2 and they have the turbo for that so your A1 should be good.
Old Apr 18, 2010
seoul4korea's Avatar
seoul4korea can only hope to improve
isn't that like 81 whp over stock? That's not bad but I would think you'd get more from 7 lbs of boost. is this on a Vtec motor or no?? I bet if you get a good set of cams in there it would be nasty. post some pic's!
-chris
mjdiaz89
Jun 21, 2016 09:26 PM
Misfit2613
Jul 30, 2015 09:49 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
fvckbg
Jul 7, 2015 07:08 PM
robbie374
Jul 7, 2015 02:56 AM
