Turboing my D17A2...
Old Dec 21, 2009
T-Funk's Avatar
T-Funk is an unknown quantity at this point
Ok so i am planning on putting a turbo on my ex, and i was planning on running about 8lbs just wanna keep it low for now. What do you guys recommend for a pretty inexpensive turbo kit, and a parts list? Are the ebay kits any good?? Is it important to do my bottom end at that psi?? And lastly, what tuning methods can be used? Is it possible to tune with afr gauge what are the ratios that i am looking for. Any info would be helpful.
Old Dec 21, 2009
Re: Turboing my D17A2...
gonna have to go with a custom name brand kit if you want any chance of having it fit. i think dezod.com still makes em for our cars. but to really do it right, you need to spend even more $$ on return fuel system, wideband o2 sensor, tuning, engine management, etc. so no, there is no cheap turbo solution. youre gonna need to spend at least $5k or more, prolly as much as a k20 motor swap.
Old Dec 21, 2009
baron340's Avatar
baron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of light
Holy mis-information batman..
There are numerous used dezod kits for sale for under 2k (like mine) /shameless plug. At just 8 psi, the only engine work you need to do is ARP headstuds and a fresh headgasket. Not a terribly big deal. That is, if your block is in healthy condition before hand. K-pro is the engine management of choice, it's wonderful, there are many threads about it. I also had a good experience with AEM F/iC for over a year, but any higher than about 9 lbs and it has issues. You will definitely need a wideband, which takes your total to 2200-ish. As for your AFR question, you will need a dyno tune. A good tune is the single most important piece of a turbo build. It is crucial, you will destroy all of your hard work without it.
Old Dec 22, 2009
04 Honda Civic's Avatar
If you say the kit is 2 grand, K-pro is another grand that's 3 grand. How does what you say make any sense. That's not including tune and probably no injectors were with your kit either. To do it right your looking at $5 grand or better.
Old Dec 22, 2009
slowassd17's Avatar
slowassd17 has a spectacular aura aboutslowassd17 has a spectacular aura about
you can turbo your car for a lot cheaper then a k swap. make you own kit, buy a decent turbo and waswastegate and blowoff valve stay away from knock offs. yes you are goin to need a wideband as for momotor work you dont have to do any internals for 8lbs of boost, buy a set of srt4 injectors or rsx-s injectors, no need to upgrade your fuel pump unless you feel you want to. and a return fuel set up isnt neccissary until around 250 to 300 whp. arp head studs are a must to prevent head lift. and arp rod bolts are also good insurance. you could easily turbo your car for around 3000 dollars give or take a couple hundred. no need to get all crazy for a low boost set up
Old Dec 22, 2009
baron340's Avatar
If you read, you would understand a little better. K-pro is superior, but not required. I'm asking 2100 for my kit, including F/iC, which has worked great for me, and will work fine for only 8lbs. I don't have injectors with it, which are less than 100.. so call it that. 2200, you have all the parts, I paid $300 for a tune from scratch on F/iC. I have since started to work in that same shop since I was a customer, and I can speak from experience, that if anyone is charging more than $300 for tuning F/iC, you need to find a different shop. So that's $2500, say another $100 for insurance, $100 for headstuds and $30 for a headgasket. That leaves you with $2700 and change, all said and done. Even including shipping charges, still less than 3k. That is about what it costs for k-swap parts, NOT including the engine and trans or k-pro.
Old Dec 22, 2009
Honda05's Avatar
Honda05 is just really niceHonda05 is just really niceHonda05 is just really niceHonda05 is just really nice
not saying gearbox is wrong or anything but you can make one yourself.. i built one from scratch and spent only 1500 for everything.. I had name brand parts as well.. dezod kits are ok but there over priced in my opinion..
Old Dec 24, 2009
T-Funk's Avatar
Ok ya that is what i figured it would cost to me to custom build it and i am already on my way there what did you use for intercooler piping that has been the hardest thing to find for me
Old Dec 24, 2009
slowassd17's Avatar
check your pm's
Old Dec 24, 2009
T-Funk's Avatar
I understand that it is not cheap to get completely set up for a turbo but that is not what i am worried about i just want the kit for a decent price and have it work and not have to worry about it failing on me
Old Dec 24, 2009
HwNpRyDe_CiViC's Avatar
HwNpRyDe_CiViC has a spectacular aura aboutHwNpRyDe_CiViC has a spectacular aura aboutHwNpRyDe_CiViC has a spectacular aura about
pm me if interested. i have a sf turbo mani that has been jet hot coated silver also has a carb legal dc sports sticket to pass inspection. also have a t3/t4 garret snail withpartial down pipe. and i got some otehr goodies
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
-HondaFTW-
Aug 30, 2015 10:38 AM
justcruzin125
Aug 11, 2015 09:09 PM
