GSX turbo kit?
Old Jul 20, 2009
HONDACIVICEM2's Avatar
HONDACIVICEM2 is an unknown quantity at this point
Lightbulb GSX turbo kit?
i used to race my old 96 Mitsubishi GSX. Now its just sitting because the transmission is messed up. I wanted to turbocharge my 04 honda civic coupe ex em2. I was wondering if you guys know anything about taking the turbo kit off the mitsubishi and building it unto your em2. Any help? please let me know because imma take off the turbo kit and see if it will fit with a custom build. Thanks.
Old Jul 22, 2009
Re: GSX turbo kit?
man this site dont have people who are kool to help me out...gayed!
Old Jul 22, 2009
dbramaged's Avatar
dbramaged is an unknown quantity at this point
Re: GSX turbo kit?
OK, so I used to have a 2002 Civic EX coupe. I used the HKS manifold to use a 16G Turbo from Mitsu (will also work with the 14b T25 and 20G, internal wastegate) then had a local shop build the down pipe which wasn't very long as an aftermarket downpipe for the EX lines up pretty well (you have to run an O2 sensor "interference system" because there won't be a Catalytic Converter. A universal FMIC works great. You can use the feed line off the back of the engine next to the oil filter. Just drill a hole in your oil pan and put a 2 lock connection on the oil pan and connect the lines.
If your turbo needs a water line, you'll have to run that off an aux line as well. Mine was just oil... If you need any more information, let me know. The HKS turbo manifold is A LOT more reliable than the tubular styles around, especially if you're running stock internals.
It ran really lean at 6-8 lbs. A Walpro 190 fuel pump and some upgraded injectors will fix that problem. Don't go over 10lbs as that's how I blew my engine. LOTS OF POWER compared to stock though.
Old Jul 22, 2009
Re: GSX turbo kit?
now we're talking thx bro...ill be looking for that manifold almost got the turbine off the gsx..thx...
HondaGuy7
Feb 22, 2016 01:00 PM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
beanhead
Sep 24, 2015 12:04 PM
