Misfire
Old Jan 27, 2009
PitchBlack's Avatar
PitchBlack is just really nicePitchBlack is just really nicePitchBlack is just really nicePitchBlack is just really nice
Misfire
Before I list my problem I'll list what I have. 02 Civic LX running 9 PSI with a Garrett T25 turbo. I'm normally running 91/92 Octane depending on what gas station I go to. 2.25 IN exhaust. I have the AEM F/IC. It also is an automatic. I have no CELs on...well before the problem started. Basically story goes like this, drove to the gas station about a 10 minute drive from my house. I was doing normal driving, got on it once or twice but nothing insane. I get to the gas station obviously shut off my car fill it up with 92 Octane. I drove off back to my house and went to get on it, but everytime I went to WOT it'd basically go to about 3k-3.5k RPMs and start misfiring across all cyclinders. I thought it was just a fluke so I pulled over shut it off tried it again same result. I've cleared the misfire codes many times after the fact and still same result. I even dumped all my fuel and put fresh gas in it with the same result. I pulled apart both the ignition and fuel system checking fuel pressure and resistance for all the injectors and coil packs. Pulled the plugs and they are in good shape as well. Any ideas on what the **** happened would be appreciated.
Old Jan 27, 2009
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
Re: Misfire
sounds like your in limp mode
Old Jan 27, 2009
PitchBlack's Avatar
Re: Misfire
I know but why is the question. There is no reason or obvious explanation for it to happen. It was running like a champ then one fill up and it goes to ****.
Old Jan 27, 2009
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
Re: Misfire
have you modified the MAP sensor at all? with a check valve or something? i was boosted at one time and the most common problem for me when it misfired was that the MAP sensor was either dirty or the filter element in there had fallen out. check that. if you used the FIC to fix the MAP/boost problem try changing the the voltage to the MAP sensor. if its not the map i would say check vtec wiring but you have an lx.
Old Jan 27, 2009
PitchBlack's Avatar
Re: Misfire
All of it was already configured and tuned so not sure why it would all of the sudden not be. I'll double check it tomorrow. Thanks for the idea. Anything helps at this point. I'm at a loss.
Old Jan 27, 2009
bomerman19's Avatar
Re: Misfire
your running a piggy back it's possible that the ecu fought with it enough that you have to go back and reset everything again. the stock ecu is very stubborn when it comes to piggy backs
Old Jan 27, 2009
PitchBlack's Avatar
Re: Misfire
So you are suggesting that I disconnect the battery basically?
Old Jan 28, 2009
Re: Misfire
idk how the FIC works but maybe you can delete the tune off the FIC and then reupload it. thats how the emanage people did it i believe. d/c the battery wont do anything because im sure the FIC has its own battery to not lose the tunes. so if you have the software and a laptop you can rip the tune off the FIC, delete it then reupload it. i guess it wouldnt hurt to disconnect your battery afterwards either.
Old Jan 28, 2009
PitchBlack's Avatar
Re: Misfire
I'll give it a shot. Thanks again.
Old Jan 29, 2009
SethWeston's Avatar
SethWeston is an unknown quantity at this point
Talking Re: Misfire
ay bra...
I don't know if you fixed your problem or not, but i had the same stuff happen
to my 01 civic ex,
first i changed my crank sensor, then it was reading my TDC sensor was bad try changing out your TDC sensor... it's a bitch in the 7th gens but it seems like it's a common with em for some reason.. that should fix it
if not clean out your vtec selinoid screen. It could be clogged
just take it to autozone n run the codes on it man... then go from there
hope i helped some if not my bad
Old Jan 29, 2009
PitchBlack's Avatar
Re: Misfire
its a LX so no worries on the VTEC and I have a code reader. Its throwing a general misfire and misfire codes for cylinder 1,2,3,&4. Those are the only codes I'm throwing at the moment but before that I had no CELs on.
Old Jan 29, 2009
baron340's Avatar
baron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of light
Re: Misfire
Have you tried pulling the ECU fuse and resetting it?
Just pull out the 15 amp fuse towards the right of the under hood panel. Its FI/ECU or something like that.
Make sure you haven't blown a fuse somewhere. Check on your map, make sure something has jacked up in the hardware itself. It shouldn't be a MAP problem, F/IC has one built in.
Old Jan 30, 2009
PitchBlack's Avatar
Re: Misfire
No blown fuses but I'll pull that fuse. You are correct it is the FI/ECU labeled fuse. It was completely random when it started acting up so who knows. I have to work all weekend so I'll try and get to it Monday. Keep the ideas coming...I appreciate all of them.
Old Jan 30, 2009
drunkenmagnum's Avatar
Re: Misfire
i would go ahead and replace those pluggs while i was at it too. I had a few that "looked" fine but weren't. cheap fix. i had the same issues but thats all that it took for mine luckly
Old Jan 30, 2009
PitchBlack's Avatar
Re: Misfire
I'll give it a shot. I checked them though with the coilpack and plugs out of the car and had a buddy look for spark from all of them. It is only misfiring when I go to WOT. Worth a shot anyway though, thanks.
Old Jan 30, 2009
ronaldo9's Avatar
Re: Misfire
Are you using colder plugs? Try lowering the boost and see if the problem still occurs. Maybe even a retune for WOT won't hurt. If you have too much timing it may misfire at WOT. I had that problem with my stage 2 cam.
Old Jan 30, 2009
PitchBlack's Avatar
Re: Misfire
I had colder plugs but switched back to the normal plugs and it was tuned with them in it. I'll try it...like I said anything helps at this point. I won't be able to touch it until Mondaythough. Thanks bro.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
runawaykinms
15
Mar 22, 2019 10:32 AM
jtcavey
Sep 30, 2015 02:18 PM
Bruce2
Sep 27, 2015 08:45 PM
Luluharp
Sep 27, 2015 11:56 AM
