Where do I find...
Old Nov 22, 2008
BoomerXx21's Avatar
BoomerXx21 is an unknown quantity at this point
Where do I find...
Where do I find sleeves for a d17a2 block? i've looked everywhere and still haven't found them for any D-series engine. also what bore pistons do I need with said sleeves and if I get a cometics head gasket what bore should that be? I feel like an idiot... Also I have decided to get a dezod turbo kit, not sure if I should get the one that comes with pistons and rods though...any suggestions?
thanks in advance
Old Nov 25, 2008
dezod's Avatar
7thgen Power Maker
Re: Where do I find...
thanks in advance
Contact Darton about sleeving your D17.
75mm for a stock bore.
Depends on your goals. The higher kits come more "bolt on" with good engine internals.
Old Nov 25, 2008
baron340's Avatar
baron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of light
you really dont need sleeves... stock sleeves are pretty beefy, and until you start to get up above 400 hp you shouldnt even be thinking about it.
Old Nov 25, 2008
joe6680's Avatar
joe6680 will become famous soon enoughjoe6680 will become famous soon enough
Wouldn't lbs of boost be a more relevant number to use as to when you sleeve or not? I don't know what the actual number is, but I am pretty sure it's the better number to go by. Not trying to be a dick or smart *** so please don't take it that way. Its just better to give proper info, and if I am wrong please tell me, we are all here to learn.
Old Nov 25, 2008
supafil25's Avatar
supafil25 will become famous soon enough
over 25 psi im guessing around 30 for sure is 400hp+
Old Nov 26, 2008
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
the engine can handle 32lbs of boost on stock sleeves that's about 500hp on a d17. hit 489hp on 30 lbs of boost on andys car saw the boost gauge go to 32 at one point on another pull
average machine shop will charge about $250 per sleeve and that is not including the cost of the sleeves. So your looking at already over a thousand dollars. New engine is between 150 and 350 dollars. If it manages to blow up with out sleeves there is a pretty good chance that the sleeves would not have saved you.
If you have a bad tune and your engine detonates enough, sleeves will not stop a rod from going through the side of the block.
Sleeves do not make an Engine Bullet Proof!!! (or bomb proof)
It is just not worth the money it's cheaper just to get a new motor and rebuild besides even with an LSD anything over 20 lbs of boost isn't that streetable torque steer is just horrific
Old Nov 26, 2008
dezod's Avatar
7thgen Power Maker
Good tuning is why Andy's car also held together nicely. THAT is what most people fail to realize. Tuning is more almost more, if not more important than the engine build itself! I can't emphasize that enough. No matter how well built an engine is, if it's tuned poorly, it is gonna break no matter what.
Old Nov 26, 2008
joe6680's Avatar
So then would it be safe to say that sleeves are sort of an insurance for a poorly tuned engine?
Old Nov 26, 2008
baron340's Avatar
uhh no... thats what was said above... a darton sleeve will NOT stop a rod from blowing through the side of the engine. the only reason sleeves are really needed in any engine is that the engine makes more horse power than the stock sleeve can handle and the stock sleeve will actually fail. problem with our engine is, the stock sleeves are pretty strong and no one has hit enough hp to need sleeves. but like it was also stated, its all in the tune. nothing will save an engine from detonating under a crappy tune.
Old Nov 26, 2008
joe6680's Avatar
^^^oooops missed that my bad.
sdaidoji
Nov 17, 2011 07:59 PM
tfnaaf
18
Sep 22, 2007 12:26 AM
gearbox
Aug 11, 2005 10:10 PM
