is this turbo usefol for my d17?
Old Oct 22, 2008
Duf's Avatar
Duf
Duf is an unknown quantity at this point
Hi,
im new here,
been driving around for about a year with i/h/e setup,
but kinda getting bored of this...
so i was thinking, why not boosting?
I have the following turbo just laying around at my garage,
but can't really tell if i can use this one for my D17 engine?
The hp goal is about 180-190whp, just a pretty street setup,
cause it's my daily...
here are some pictures with measurement (everything is in milimeters, not inches, if wanted i can convert it to inches...)
turbine outlet
http://www.mijnalbum.nl/Foto-KGJYRCEI.jpg
turbine inlet
http://www.mijnalbum.nl/Foto-OS6MKCSQ.jpg
Compressor inlet
http://www.mijnalbum.nl/Foto-7OBB8YQA.jpg
compressor outlet
http://www.mijnalbum.nl/Foto-ZTZDYEL7.jpg
turbine inducer
http://www.mijnalbum.nl/Foto-ISBYSKNY.jpg
turbine exducer
http://www.mijnalbum.nl/Foto-E6ZWJO7R.jpg
compressor exducer
http://www.mijnalbum.nl/Foto-4VN8VSDS.jpg
compressor inducer
http://www.mijnalbum.nl/Foto-WBOI77M3.jpg
Compressor trim: 41
turbine trim: 86.75
compressor A/R: aprox 6mm
Thanks in advance
Old Oct 22, 2008
boxcarracer's Avatar
boxcarracer is a jewel in the roughboxcarracer is a jewel in the roughboxcarracer is a jewel in the rough
Re: is this turbo usefol for my d17?
Flange type? Is that a DSM turbo?
Old Oct 22, 2008
Duf's Avatar
Duf
the flange is one with 3 bolts (don't know the type),
it is a mitsubishi turbo
Old Oct 22, 2008
i think dont quote me on this its a TC05 Turbocharger 85-88 Mitsubishi Cordia 1.8L from what i found... ur gunna need that manifold or make a custom manifold, to trouble for a old turbo get a ebay kit junk the manifold it brings and try running that, if not go all out www.dezod.com
Old Oct 22, 2008
Duf's Avatar
Duf
yeah, it is a tc05 turbo indeed,
making a custom manifold seems a bit big for a first time,
and was already thinking to junk a ebay manifold as a testing purpose
do you think it will be worth the effort using this turbo?
Old Oct 22, 2008
honestly not really worth it i guess if it was new but its old and its a mitsu turbo i had dsm 2 turbos kept going...shaft play i blame its age not the turbo
Old Oct 22, 2008
Duf's Avatar
Duf
then, what turbo can you advise me to reach my goal?
Old Oct 22, 2008
i guess an ebay kit much easier to get look at what ebay is selling t3 setups if its blow then whatever change it Try looking at www.dezod.com to see the setups they sell use that as a guide to what you will need then ebay some stuff if you arent to serious about to much power considering you want about 180hp shouldnt be to hard
Old Oct 22, 2008
Duf's Avatar
Duf
Thanks for the tip!
but i have another question,
when i fix al those things, should there be anything changed to the electronics? or is this not neccesairy?
Old Oct 22, 2008
emanage.. which is for tuning and making sure your car runs correctly with the new flow of air and more fuel being used look up on this forum the FAQ Turbo set ups There are other things you can use but thats the most common that i can think of at the moment
Old Oct 22, 2008
Duf's Avatar
Duf
looking at this kit:
http://cgi.ebay.com/ebaymotors/01-05...mZ380074947805
is it something that would be useful for me? or just junk?
or
http://cgi.ebay.com/ebaymotors/JDM-U...mZ250312258202
been looking at the emanage faq, but that's really chinese for me :O
Old Oct 22, 2008
Id go with the first one just change the couplers with better ones in the future that should be just fine for bolt on kits. You should reach close to your goal t28 is fine you can always change in the future the pipings fine you can keep that same with the intercooler. I dont know why ebay kits get bad reps of course its no dezod kit but it gives you the most important parts for some fun
[QUOTE=Duf;4356014]looking at this kit:
or
http://cgi.ebay.com/ebaymotors/JDM-U...mZ250312258202[/QUOTE]
Old Oct 22, 2008
Duf's Avatar
Duf
thanks for the tips man!
really usefull for me thanks alot!!!
Old Oct 22, 2008
supafil25's Avatar
supafil25 will become famous soon enough
ive been running an ebay kit t3 t4 for 2 months now
0 problems!!!
and you can use that mitsu turbo just need to make flanges
Old Oct 22, 2008
Duf's Avatar
Duf
supafil,
are you sure?
do you have any idea what i would score with ths mitsu turbo?
Old Nov 1, 2008
supafil25's Avatar
im pretty sure that turbo can push over 25 psi
would be 350 + hp easily
but you need a built motor and hondata
thats a lot of money
Old Nov 1, 2008
supafil25's Avatar
i had 2 mitsu 20g's but i sold them b4 i had the chance to use them
Old Nov 1, 2008
02civicg5's Avatar
02civicg5 will become famous soon enough
i was wondering how good r our motors?? can they hold boost wit stock internals.. can they hold on boost wit no problem?? just bolting it right on?? and if so how much power can u get out of it witout blowing??
Old Nov 1, 2008
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
Yeah tell me 350+ whp is easy once you get there. I'm pretty sure you will eat those words the longer you have that ebay kit. Been there, done that.
A mitsu turbo will work if you can get it bolted up to a manifold, it would likely be cheaper to find another turbo. If you are asking these questions, take your time planning and especially learning how OBD2 ECUs work. Bolting it together is only half the battle.
Old Nov 1, 2008
supafil25's Avatar
im not at 350 not even close. im running my own kit that i put together and put on of ebay. but all i need is LC pistons, rods, injectors, kpro, and a good tune and i could be making 350+
all i need is money=(
Old Nov 1, 2008
widegts's Avatar
widegts is on a distinguished road
If any one is interested I have a mitu turbo t25/t28 flanged.It is a garrett. It is the td05h basically a t25.
-holds 300hp
- water cooled
-3 bolt exhaust outlet
If anyone is interested shoot me a pm for pics. Ill let it go for cheap since Im using a little bigger turbo.
Old Nov 1, 2008
supafil25's Avatar
how much you want
Old Nov 1, 2008
02fpcivic's Avatar
Thats like saying if I put a 300 shot on my built engine I COULD be making 600+whp. My point was everyone thinks its easy to make all kinds of numbers because they see someone else do it. Actually getting the **** together to do something is much more of a challenge than picking out parts in a catalog and planning a build.
Old Nov 2, 2008
supafil25's Avatar
well it depends on your mechanical abilities... for me everything i did to my car so far was easy.... so maybe for you it wasnt but for me it was a task but still easy
Old Nov 2, 2008
02fpcivic's Avatar
Do you have any idea who I am or what I am capable of? Any of the OG members have at least an few onces of respect for what I have done for the 7th gen community. You think because you bolted on a $2 ebay turbo kit that you know something? Build a car by hand, build me a full tube chassis, a hand made intake manifold, try designing a manual timing belt tensioner conversion that works flawless because the custom cam that Brian Crower cut you is so big that the belt slacks up every time you run the motor. I wipe my *** with bolt-ons, so dont get sarcastic with me.
Old Nov 2, 2008
speedfoos's Avatar
Meh. You got no skillz Gerry. JB Weld, zipties and hose clamps only go so far.
Oh wait. That's my car!
Old Nov 2, 2008
02fpcivic's Avatar
I will eventually figure out what I am doing. I got to get one of those car modding for dummies books, it has all the answers. I hate to put up those "modest" posts seeing as I am usually a pretty humble dude, but people toss out numbers on the 7thgen forums like its nothing to see 350+ whp D17s. You know and I know what it takes as well as a select few others. Its alot more respectable for someone to look down from the peak of a mountain and say the climb was nothing, than too look up and say its going to be a cakewalk.
Old Nov 2, 2008
widegts's Avatar
Your on a honda civic site, you can expect too much... The majority have no clue what it takes to build a quality kit or how to get there. They buy a cheap kit and run 20psi on it and expect a miracle.
Old Nov 2, 2008
02fpcivic's Avatar
I suppose you are right, hehe.
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Donahue
Sep 8, 2015 09:00 AM
KAMIKAZEEx
Aug 30, 2015 08:30 AM
justcruzin125
Aug 11, 2015 09:09 PM
