Help me with turbo!
Old Sep 7, 2008
RondaTheHondaSI's Avatar
RondaTheHondaSI is an unknown quantity at this point
Help me with turbo!
I drive a 2005 civic si hatchback with all the basic performance (headers,downpipe,exhaust system,intake) and i was wondering if i should go for turbo or if there is any other performance i could do in place of it,and if i should go with turbo what kind and what specs should i get
Old Sep 7, 2008
Eyger's Avatar
A long winded 7th genr
Eyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond repute
Re: Help me with turbo!
Everyone will probably tell you to search. Either that or pick up a couple of books on turbos and see if it's what you wanna do. The transportation section in borders has all kinds of books on what you can do to make your sport compact car faster. Some things you might consider looking into if you're not going to do turbo would be an intake manifold, engine management, camshaft, or even an engine swap if you really wanna do that.
Old Sep 13, 2008
I love my engine so i wouldnt swap it, i just wanna tweak it some to get a little more goose out of it
Old Sep 13, 2008
7th_gear's Avatar
7th_gear will become famous soon enough7th_gear will become famous soon enough
speedfoos posted this for me when i asked a question around the same guidelines, you might not take it seriously, or you might. No matter how you look at it I knew dick about turbos when i asked the question, now i now a littel bit, the book actually helped alot, hit it up if you can.
You need to search. A lot. Buy or check out Corky Bell's "Maximum Boost" from your library.
Then go read the FAQs in Forced Induction section.
Then read this:
http://www.beesandgoats.com/boostfaq/g2icturbo.html
Then go and look around the F/I section some more.
Then go look at the only reputable retailer who sells a turbo kit for our car. www.dezod.com
Old Nov 1, 2008
supafil25's Avatar
supafil25 will become famous soon enough
i would deff go turbo the best investment i ever made!!!
Old Nov 2, 2008
jamis33's Avatar
You Stay Classy, San Diego
well if you have an si hatch that means you have the k20a3 engine so for a bit more performance you could get the a2 or z3 head for your car. Your car puts out like 160hp now and a k20a2 puts out 200ish. and the head swap would cost you less than 1000 i think. also look into supercharging. ive heard that supercharging a k20 is very effective and it isnt as much of a hassle as a turbo
Old Nov 5, 2008
quinnmyster's Avatar
quinnmyster is an unknown quantity at this point
Talking Re: Help me with turbo!
Well DUDE... have you ever been in a turbo'd car? It will pull you back in the seat when it kicks in, and ESPECIALLY with that K20 motor! Dam, you can run 10psi on stock internals, I hear those motors are such a strong block! You just need to ride in a friend's boosted car and you'll be sure to boost However, those Honda motors running n/a at 230whp are going to put you hella back in the seat TOO, so... that would be gnarly. Can't you do a head swap to a newer K20 head?
Old Nov 5, 2008
sicma99ot's Avatar
just a man with a civic
sicma99ot is a glorious beacon of lightsicma99ot is a glorious beacon of lightsicma99ot is a glorious beacon of lightsicma99ot is a glorious beacon of lightsicma99ot is a glorious beacon of lightsicma99ot is a glorious beacon of light
if i had a k20 engine i would def. do an n/a build. most of us with d17 prob. wouldnt see those kinda number with a turbo.
but since i have a d17, i wouldnt swap. just build on what i have. sure it would cost more to build my engine than to swap, but i dont care. its half the fun.
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
-HondaFTW-
Aug 30, 2015 10:38 AM
justcruzin125
Aug 11, 2015 09:09 PM
