walbro fuel pump alternative?
Old Mar 24, 2008
dust's Avatar
dust is an unknown quantity at this point
Hey all boosted guys and whatnot, since im using rsx-s injectors in my boost build couldnt i run the rsx-s oem fuel pump instead of the walbro? Also when accessing the oem pump can i get to it from under the rear seats instead of having to remove the entire fuel tank?
Old Mar 24, 2008
speedfoos's Avatar
Re: walbro fuel pump alternative?
Hell, you can run the stock pump with those RSX injectors. It will have no problem keeping up with them. When it is time to replace it though, yeah, you do access it from right underneath the backseat.
Old Mar 25, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
yeah its been a fact for awhile that the stock fuel pump can handle a bit more than the rsx 310cc injectors. stock will be fine until you upgrade to maybe srt4 injectors
CarStuff
Dec 6, 2020 12:52 PM
Jonnie.
Jan 13, 2019 11:21 AM
JoeB16
61
Oct 16, 2003 07:58 PM
htowncivicEX
Jan 21, 2002 11:48 AM
