K20a3 Throttle Body Clearance, Help!!
Old Mar 3, 2008
Kore's Avatar
Kore is an unknown quantity at this point
Sup guys
I need help from those of you who have completed your k20 swap.
I have a k20a3 with a type-S intake manifold and i'm having trouble
with clearing the front support member with the base model throttle body.
the reason is that the spring sits on the oposit side from the type-s (against the support member) so the throttle body needs more space to clear.
I'm thinking that if i buy a space it may clear but i'm not sure. I really don't
want to buy a type-s throttle body (don't want to spend another $500). Also
is there a way to remove part of the throttle body spring (cruise control, not using it)?
Thanks
Old Mar 3, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
Re: K20a3 Throttle Body Clearance, Help!!
well if you are swapping into a 7th gen civic i dont see any reason why an oem manifold wouldnt fit. there are plenty of 7th gens running RBC intake manifolds and it fits perfectly. it brushes on the rad support and needs a little trimming but thats about it. if a RBC fits then there is no reason why the stock wouldnt fit
SammySC
121
Apr 7, 2017 07:43 PM
carid
Sep 28, 2015 10:13 AM
Bruce2
Sep 27, 2015 08:45 PM
2.0.0.2
Sep 14, 2015 06:38 PM
Bricoleur
Sep 9, 2015 12:30 PM
