crower rods issues please help asap!!!
Old Dec 4, 2007
HwNpRyDe_CiViC's Avatar
HwNpRyDe_CiViC has a spectacular aura aboutHwNpRyDe_CiViC has a spectacular aura aboutHwNpRyDe_CiViC has a spectacular aura about
hey guys my car is at teh shop as we speak.. the builder called me and said teh crower rods for our cars are short. are they suppose 2 be shorter than the stock d17a2 rods??? please et me know asap
Old Dec 5, 2007
Re: crower rods issues please help asap!!!
crower has all there rods heighst listed at 5.393 but isnt teh stock rod height 5.511 for a d17!!dosent teh rods have to be teh same size height wise??
Old Dec 5, 2007
does this mean all teh crower rods for d17's are made incorrectly and all teh rods people have bought are faulty or not made to teh correct sizing needed?
Old Dec 5, 2007
ryox82's Avatar
ryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to all
can ya do me a favor and at least TRY to spell the easy words right. You almost gave me a seizure. As far as the rods, PM triz, I know he was messing with their springs too, maybe he did the rods as well. I find it hard to beleive that crower sells a whole rob/spring/retainer kit for our engines and it is WRONG. I would expect that from ebay lol.
Old Dec 5, 2007
dezod's Avatar
7thgen Power Maker
Several people run their rods and there is no problems with them. Where are you getting your measurements from?
Old Dec 5, 2007
ryox82's Avatar
hahah im crabby when I wake up
Old Dec 5, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
You have to run an aftermaket slug. chances are.... the height difference has been accounted for in the piston. With the slug on it, the assembly comes out a little below the deck height like it should, so I dont see any issue with it. Also depends where you're measuring from.... the crowers require a bigger pin, so if the measurement is somehow based the holes it may be effected. The deck of the piston is quite short. I never checked the piston dimensions but my guess is the pin moved down a little bit, because there's not a whole lot of room to move it up.
Old Dec 5, 2007
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
I hope you are planing on using forged pistons.
You'll have to machine the stock pistons to take on a bigger rod.
Crower rods are build for racing and made to fit forged pistons witch are ready to install and highly recomended if you are this far into your build.
good luck!
Old Dec 5, 2007
yeh i have weisco 8-1 comp pistons ...but the crower d17 rods are shorter then my stock rods. arent they suppose to be the same height as the stock rods?
Old Dec 5, 2007
weisco 76mm 8-1 comp pistons/darton sleeves/crower f/i rods - $1125
Old Dec 6, 2007
LogicWavelength's Avatar
7th Gen Photographer
LogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of light
I am running the wiseco turbo pistons and crower turbo rods... (I forget all the numbers and stuff) but short of a weird scrapping noise that the pistons make, it runs perfectly fine. I believe the rods are shorter to accommodate for the beefier pin on the piston so that they can withstand all the additional stress of racing.
Old Dec 10, 2007
emjay's Avatar
emjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the rough
why do u mean a wierd scrapping noise?? u always hear this when driving .. that must be messed up
Old Dec 10, 2007
It just sounds like the pistons make noise when they move in the cylinders. I've heard other cars with aftermarket pistons and they sound similar... it just doesn't sound stock anymore is what I'm trying to say... the sound of the pistons travelling up and down is audible. I talked to WISECO and they said that's because of a 3/1000s honing they recommend with installing that particular piston kit to allow for the aluminum to expand.
The sound goes away as the engine heats up, so I believe their explanation.
Old Dec 10, 2007
supermex's Avatar
[logicWavelength;4270045]It just sounds like the pistons make noise when they move in the cylinders. I've heard other cars with aftermarket pistons and they sound similar... it just doesn't sound stock anymore is what I'm trying to say... the sound of the pistons travelling up and down is audible. I talked to WISECO and they said that's because of a 3/1000s honing they recommend with installing that particular piston kit to allow for the aluminum to expand.
Dido,
When my engine is cold sounds like valve ticking noise till it gets warm.
I also have some oil bypass in small quantities.
Is normal on racing engines.
De Civic:
Here is piston / Rod assembly
On the following picture noticed how the center pistons don't go to the very top of the sleeves
(is realy not that much, the pistons where on their way down)
is about 1/8''
You may have to notch your block sleeves to clear the rods.
Old Dec 10, 2007
ok check it. crower totaly made the rods wrong spec. even tho they do work for our cars as proven. the rod height is off. they made the rods for our cars the same as a d16 rod but we have a rod size of 5.511 and the d16 is 5.343.not alot but still made incorrect.. and why would some people have to notch there sleeves and some wouldn't that is weird.if 1 person would have to wouldnt all of them since the specs are the same. crower is selling rods that technically are not for our cars seeing that its made with d16 rod height specs. i have 2 wait and see what crower says.
but supermex - ur pistons dont touch teh top and they do stay below a little also did u notch ur sleeves because teh rods were going to hit the sleeve walls or u did it just incase it was going to?
Old Dec 10, 2007
dezod's Avatar
7thgen Power Maker
Where did you order your rods from?
Old Dec 11, 2007
They didn't have to notch my stock cylinder sleeves... maybe only notching the aftermarket ones? I bought mine from Dezod so that's why there was no problem!
Old Dec 11, 2007
yeh i have darton sleeves but teh rods dont hit them is that usual dezod? and i go tmy sleeves from a a memebr here who got them from a shop.
Old Dec 11, 2007
dezod's Avatar
7thgen Power Maker
There should be a part number stamped on the box of the rod. What is it?
Old Dec 12, 2007
Jap-Euro Fusion
I pulled the tag out of my box of rods... its the same 5.3whatever he said it was. I never noticed, but the motor doesnt seem to really care.
Old Dec 13, 2007
ok i went to my shop and gave teh go ahead. leme ask u thin since teh pistons are 8-1 compression and since the rods are shorter than that means the compression is really aorund 7 1/2-1 or 7-1 for everyones motor correct?so my builder says were gonna have to boost 17-20 daily to compensate which is ok since its a built block..
Old Dec 14, 2007
What fuel system are you going to run to reach 17psi? Sounds expensive already
Old Dec 14, 2007
skipbarber's Avatar
there is no way that a few hundreths of a difference in rod height is going to drop your compression from 9:1 to 7:1...and if it does, it's going to take forever to start. are you running a full stand alone?
Old Dec 14, 2007
8-1 weisco pistons not 9-1 and im runnin ems
Old Dec 14, 2007
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
umm random question... Your building your motor for boost right? How "Short is your piston+Rod assembly to TDC? Is it short enough for the correct Compression ratio? Or is it so short as it would be something like 1:1:?
Old Dec 14, 2007
its off liek how super said about 1/8.. so my compwould prollly be what i posted above. and yes building for boost
Old Aug 25, 2008
gmcuajo's Avatar
gmcuajo can only hope to improve
I just saw this thread and I am curious, do you solve this "problem"? I think all you where doing is meassuring it wrong...
bravo79
Suspension
18
Feb 10, 2022 09:52 PM
B1zZ
Bolt-on Engine Performance
Jun 2, 2015 11:42 PM
El_Spic
Apr 23, 2015 03:14 PM
JoeB16
61
Oct 16, 2003 07:58 PM
ACEM2
Feb 11, 2002 08:50 AM
