hooking up greddy presure harness and sensor?
The yellow end gets plugged into the emanage but where does that black clip plug to?
A vac line goes to the sensor (im using the brake booster as main vac source. Is it ok to just run a line off the vac distribution block to the sensor?) but where does that grey clip plug into?
Re: hooking up greddy presure harness and sensor?
I think you have a sensor with a long wire that plugs straight into the blue box.
I have been told yellow emanage, black clip plugs into the sensor and a vac line goes to the sensor as well. I that how you normally would hook it up?
I figured it out... For those of you who are lost. That grey clip is now the yellow clip. Greddy changed the color from grey to yellow. The bag has the harness already attached to the sensor. So here is how youd hook it up. Yellow clip to emanage, black clip to the map sensor, then a line to a vac source.
Are you and Honda05 working on the same turbo setup on the same car?
I ask because I'm seeing the same questions on the same gear posted or Pm'd right around the same time. That and you two also have the same Carbon Works graphic in your sig block.
No biggie, but my mom said she drowned all the stupid ones and I just want to prove that she didn't miss one!
If mom drowned all the stupid ones why are you still around? I guess infact she did miss one.
Official Rattlesnake Hunter
You should check your pm that I sent you about the vac line pertaining to the catch can, I already told you Im helping a friend install a kit on his 7th gen. They friend is honda05.
Not sure Don. I'm hoping he's kidding and it just came across poorly in text. If not, I really regret going out of my way to help him and his buddy with all their turbo ****.
I took offense to the comment he made in the first post. So if that was some sort of joke, it wasn’t really funny at all. I took it as you insinuating that I or Chad were “the stupid ones" so I gave it right back to you. If that wasn’t the case then don’t mind the comment...
I was referring to my mom drowning all my stupid brothers and sisters, but not me, since I was able to use my mad deductive reasoning and superior intellect to figure out that you two are working on the same car. Wasn't referring to you and Chad at all. Last time I checked, you weren't my brother, but my Dad is a little shady so it wouldn't surprise me.
I had forgotten who you said you were helping with the turbo install in the PMs we had back and forth. Short term memory is for punks and I refuse to use it.
Looks like a case of misperception so we'll leave it at that.
BootyDo
Jun 21, 2016 03:45 PM
jzhartman
22
Jul 23, 2015 10:42 PM
mistermenphis22
Jul 13, 2015 04:43 PM
robbie374
Jul 7, 2015 02:56 AM
