Anyone with a K swap I need a small part from the D
Yes I do.
My freaking alternator tensioner bolt fell off,
Honda don't have one on stock they can get one next week but they want too much.
If you still have all your old parts I would buy it from you.
I will scan the diagram showing the part that's needed.
Re: Anyone with a K swap I need a small part from the D
The bolt off the front sway bar mount (at least the one off a 2003 ex coupe) will fit it. I had mine fall out and I found that one of the stock bolts from the bracket that holds my front sway bar on had the exact same pitch and was the same size. Thats the great thing about Hondas half the stuff on them is interchangeable. I do have a spare bolt though, if you still need it pm me.
Dude, you so don't need that bolt. I haven't used one in years...literally. All you have to do is put the belt on, pry the alternator away from the block until the belt is good and tight, then tighten down the bolt that holds the tensioning slide down onto the alternator.
I do need it
If oyu have one send it my way
Tell you what...if you can get me that info on the axles, I send it out to you for nothing...
I'll have to go through my box of bolts tonight to see if I can track it down, although I'm not 100% sure I have a winged bolt, I might. I'll check for you.
Just lifted the car last night and I couldn't find any numbers.
I'm arguing with my mechanic about that alternator install so he is being an *** and he is telling me that he can't find any paper work on for them
I'll still press on and see what info I can get soon.
I do appreciate you looking for that bolt
He didn't give you a receipt or spec sheet or anything? That's lame. Even the compressed measurements would work. Damn I wish I had a spare set of axles sitting around so I could measure them myself.
This is not my original guy is someone else I used because my guy was at the races that month.
I'll never use him again.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
Ma213802
May 18, 2015 07:01 AM
SoyerOner
May 11, 2015 09:46 PM
