aem cam gear
Old Aug 27, 2007
thefivespeeder's Avatar
thefivespeeder is a jewel in the roughthefivespeeder is a jewel in the roughthefivespeeder is a jewel in the rough
aem cam gear
Are they even worth it?
Running a 75 shot now, but I have
hks mani
t25
crower stg 2 turbo cam, spr+ret
rsx-s inj
emanage ultimate
so would it even do anything or just look pretty at 0degrees lol
thanks!!
Old Aug 27, 2007
Re: aem cam gear
for you its worth it but only if you get it dyno tuned. get the 5 bolt not the old 3 bolt that has been known to come loose and blow up engines. only downside is the stock dust cover does not fit over it, so its open to whatever rocks and junk can fall in and stall it
Old Aug 27, 2007
Re: aem cam gear
How much do you think I could even get out it??
thanx btw
Old Aug 27, 2007
HwNpRyDe_CiViC's Avatar
HwNpRyDe_CiViC has a spectacular aura aboutHwNpRyDe_CiViC has a spectacular aura aboutHwNpRyDe_CiViC has a spectacular aura about
Re: aem cam gear
who told you thi sbro? its not ture. i have a 5 bolt on right now and i have nothin modded cover wise. fits perfect...
Old Aug 27, 2007
bullet02ex's Avatar
bullet02ex will become famous soon enoughbullet02ex will become famous soon enough
Re: aem cam gear
i would say its worth it and you'll see a slight gain from it
Old Aug 27, 2007
Re: aem cam gear
ok, hey thanks a lot guys!! def appreciate it
Old Aug 27, 2007
skipbarber's Avatar
Re: aem cam gear
dont bother, dump the emanage and get the kpro with the aem gear instead..
Old Aug 27, 2007
Re: aem cam gear
ems is also good but a cam gear is a good thing to have....better 4 ur enine if its modded turbo wise.also if u tryna go na but i dunoe about na on a d17
Old Aug 27, 2007
Re: aem cam gear
weird, we put the cover on and it ate through half of it. had to remove and it was all chewed up inside.
Old Aug 28, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
Re: aem cam gear
Its only got 1 cam.... the gear isnt going to do a hell of a lot, because you cant phase intake and exhaust separately. You just advance it all the same amount, or retard it all the same amount. You might gain 2 HP playing around with it, but with boost.... you can make 2 HP with an extra 1/4 psi, so why bother?
It works well on twin cams because you can adjust the overlap of intake and exhaust, but with a single cam, it does very little for the effort.
carid
Nov 7, 2015 01:46 AM
naokigoffi
Aug 30, 2015 06:19 PM
WaryDriver
Aug 16, 2015 11:22 AM
Theshwartz35
Jul 17, 2015 11:13 PM
Ccoop87
Jul 9, 2015 03:26 PM
