Turbo Spool
Old Aug 14, 2007
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
Turbo Spool
ok so I got one for the panel. I noticed yesterday working on my car that @ idle the compressor wheel stopped spinning, completely. So I blipped the throttle & it came back......it doesn't always stop, but sometimes it will if you watch it long enough...
I've never had a turbo car before but the mechanics on a turbo & exhaust manifold say otherwise.....it is bolted directly to the exhaust ports, surely the flow from the engine never stops enough not to spin the turbine at least alittle.
Is this normal or is my 5027E Precision Turbine toast? I really love it. It spools great! Awesome turbo!
Old Aug 14, 2007
7thgen.nick's Avatar
7thgen.nick has a spectacular aura about7thgen.nick has a spectacular aura about
Re: Turbo Spool
I dont know too much bout em, but that doesnt sound normal
Old Aug 14, 2007
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Re: Turbo Spool
Wo, im no turbo guru but sounds like the turbo need to be rebuilt...
i dont know though, bump for answers.
Old Aug 14, 2007
trurace's Avatar
trurace is a jewel in the roughtrurace is a jewel in the roughtrurace is a jewel in the roughtrurace is a jewel in the rough
Re: Turbo Spool
It is fine. My turbo does the same thing at idle. I got freaked out too when I saw my turbo was doing that at idle. I am no turbo guru either, so I could be wrong and both our turbo's could be toast lol.
Old Aug 14, 2007
LT2004ever's Avatar
I wil fix vBPlaza today
Re: Turbo Spool
pm andyman!
Old Aug 14, 2007
dezod's Avatar
7thgen Power Maker
Re: Turbo Spool
Guys slow down here!!! The turbo is fine if it does not spin at idle. That means the turbo is a little large for the application. So long as it is making boost, there is no oil anywhere and the comp wheel still spins with no shaft play, you're fine.
Old Aug 14, 2007
speedfoos's Avatar
Re: Turbo Spool
^^^^There you go. Paul to the rescue again.
Old Aug 14, 2007
DsevenEm2's Avatar
This is Myspace
Re: Turbo Spool
i dont get it tho...at idle..isnt air still coming in and out of the engine? so if the turbo is connected to the exhaust manifold..shouldnt the exhaust gases still be pushing past the turbine? there for making it spin??
oorrr
are the gases being pushed out at idle..not strong enough to move the turbine...?
Old Aug 14, 2007
speedfoos's Avatar
Re: Turbo Spool
Its a matter of compressor size and pressure. If you've got a big turbo with a large interior volume, a D17 at idle will not create enough pressure to spin the turbine, it'll just flow past the blades without spinning them.
So you're close on your second guess, its just a little more involved than that.
Old Aug 14, 2007
dezod's Avatar
7thgen Power Maker
Re: Turbo Spool
Exactly. The exhaust pulses are not large enough to make the turbine wheel spin at all times. That is all. The turbine trim and A/R has a lot do with this.
Old Aug 14, 2007
02BLKCIVIC's Avatar
Re: Turbo Spool
Coooool
Old Aug 14, 2007
FoSho's Avatar
Re: Turbo Spool
Thanks for clarifying dezod, I was gonna give Paul a buzz but I abuse him too much!! haha. Also another important note ** the turbine is also turned by the expansion of heat from the exhaust ports not the flow of exhaust by itself.**
Old Aug 14, 2007
DsevenEm2's Avatar
This is Myspace
Re: Turbo Spool
oh really... wow... i love this place. i learn too much sometimes.
Old Aug 15, 2007
dezod's Avatar
7thgen Power Maker
Re: Turbo Spool
The hot exhaust gas pulses turn the turbine wheel. Simple as that. 'Flow' is a generic loosly used term we all throw around, but the technical jargon, which this forum did not need to know, is that. I prefer the K.I.S.S. method. Ya know?
Old Aug 15, 2007
02BLKCIVIC's Avatar
Re: Turbo Spool
Keep it simple stupid!!!!
i used that phrase in sales!!!!
Old Aug 15, 2007
FoSho's Avatar
Re: Turbo Spool
Man, I'm a honda/toyota service advisor, I keep it simple all day long with my customers! Can't I use my technical mumble somewhere!?!?!?!
Old Aug 15, 2007
DsevenEm2's Avatar
This is Myspace
Re: Turbo Spool
honda-tech
Old Aug 15, 2007
dezod's Avatar
7thgen Power Maker
Re: Turbo Spool
honda-tech
Old Aug 15, 2007
FoSho's Avatar
Re: Turbo Spool
Haha, nah.....those are just trained idiots with a huge amount of honda info in front of them. It's a rarity that you get one with any real field experience.
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
-HondaFTW-
Aug 30, 2015 10:38 AM
justcruzin125
Aug 11, 2015 09:09 PM
