Good news coming for engine building D17 owners
Old Aug 9, 2007
dezod's Avatar
7thgen Power Maker
Finally!!!! After years of begging and shopping the notion around, we where able to close the deal on getting more cost effective connecting rods coming to the market. In a few weeks, you fellas can expect to see them on our site. These will be an H-Beam design made by a Carrillo company. So this should be interesting.
Old Aug 9, 2007
speedfoos's Avatar
Re: Good news coming for engine building D17 owners
OOOO!!!
Can you give a ballpark on the price Paul? Within $75-100 is fine with me. That will help me make the determination to go with Y8 internals or stick with the D17s.
For boost or NA? Or does it matter?
Fantastic stuff. Between these and the LSD you guys are pursuing, I couldn't be a happier Honda owner!
Old Aug 9, 2007
familycar's Avatar
carillo makes stout rods. i actually used to know the owner. i did the windows at their san clemente office for about 5 years.
Old Aug 9, 2007
dezod's Avatar
7thgen Power Maker
Originally Posted by speedfoos
OOOO!!!
For boost, and they will run around $400-475 for the set of 4!!!!!
That is atleast $200 cheaper than Crower.
Old Aug 9, 2007
speedfoos's Avatar
Holy circus midgets, Batman! That's actually reasonable!
Will the block have to be notched like we have to with the Crowers?
Old Aug 9, 2007
Yaj00003's Avatar
Yaj00003 is an unknown quantity at this point
Which will still be better Crower or Carrillo ?
Old Aug 9, 2007
ronaldo9's Avatar
This is great finally d17 parts prices are coming down.
Old Aug 9, 2007
sql_civic's Avatar
Alright.
Now I'll need custom pistons instead of custom rods.
Old Aug 9, 2007
dezod's Avatar
7thgen Power Maker
Originally Posted by sql_civic
Alright.
No need for either. Crower makes rods, and Wiseco makes pistons:
http://www.dezod.com/pd_crower_maxil..._rodscivic.cfm
http://www.dezod.com/pd_dezod_motors...erformance.cfm
I know, right.
These should be almost as good, if not better.
More than likely.
Old Aug 9, 2007
trurace's Avatar
trurace is a jewel in the roughtrurace is a jewel in the roughtrurace is a jewel in the roughtrurace is a jewel in the rough
Hey Paul, which would be better for me.
Stg 2 cam and standalone (aem or kpro)
or
pistons/rods and up the psi but stay with the pcs
Old Aug 9, 2007
bigmax1665's Avatar
bigmax1665 is an unknown quantity at this point
Originally Posted by dezod
well, we need to get custom pistons if we're going na, somebody needs to come out with some high compression pistons.
Old Aug 9, 2007
TRIZ's Avatar
You knew this question was coming from me...
Can we use these on NA and see results like the crower rods, and if not- why?
Old Aug 9, 2007
tfnaaf's Avatar
BLDNPSI Mod
what are your horsepower goals for N/A ? I cant forsee a N/A D17 needing these. Unless you just want teh extra security.
Old Aug 10, 2007
TRIZ's Avatar
Well, goal is in the ballpark of 160 for now.
For power reasons, might not need them, but once the specs get put up, would be nice to run some lighter rods if they are.
Question- can we run aftermarket pistons on our stock rods- any issues there?
Old Aug 10, 2007
exturbo6's Avatar
well not for nothing, it would be cool to see a fully built NA em2. pistons, rods, stage 2 cam, standalone. rev that bitch to 9k. btw like ur vid for the head!
Old Aug 10, 2007
drunkenmagnum's Avatar
perfect timming, i just paid my car off so now i can afford these!
Old Aug 10, 2007
dezod's Avatar
7thgen Power Maker
My thoughts exactly tfnaaf.
We can make them higher compression. Just call to order.
or
I recommend these rods and AEM if you want to get really serious Rich. How is she running BTW?
Old Aug 10, 2007
sql_civic's Avatar
Well not really. I need 78mm pistons for 10:1 compression. Can you make them?
Old Aug 10, 2007
dezod's Avatar
7thgen Power Maker
So 3mm OB and small increase in suds to 10:1? I am sure we can, but it will be extra $$ and 4-6 weeks.
Old Aug 10, 2007
sql_civic's Avatar
I'll send you an email and maybe you can propose the parts and cost. It's for a winter build so there's time.
Old Aug 10, 2007
bigmax1665's Avatar
what would an estimate be on some 75mm 12:1 comp pistons
Old Aug 10, 2007
dezod's Avatar
7thgen Power Maker
$515 plus s&h
Old Aug 10, 2007
trurace's Avatar
Im still having a really bad over heating problem. I've change the radiator and them thermostat, but its still overheating. Im thinking I have a blown HG, but the cars not showing any signs of a blown HG and still runs hard. I dont know, ill figure it out. I am just going to use this down time to build enigine.
So those rods and AEM? What about pistons?
Old Aug 11, 2007
TRIZ's Avatar
^ any white stuff on the inside top of the oil cap?
Old Aug 11, 2007
trurace's Avatar
Not by the car to check, but im pretty sure there is no white stuff
Old Aug 13, 2007
dezod's Avatar
7thgen Power Maker
Yes. Go Wiseco or we can get a custom one made from JE or something.
Old Aug 25, 2008
gmcuajo's Avatar
gmcuajo can only hope to improve
$515 plus s&h
I am looking for some "stock-to-high" compression forged pistons to run around 100hp shot. Not too high compression because for now (budget) I will use the stock D17A2 cam, then upgrade to a stage-2. What compression you think will be good for it? By now I am running 60hp shot but want more.
And about the K1 Technologies rods? I can install them matching clearance with stock Honda (d17) bearings? I really don't want to take-off the entire from the car to give it to a machine shop.
Old Aug 27, 2008
army12bc's Avatar
army12bc will become famous soon enough
so i take it nobody has tried to build a d17a2 with around the specs around 11.5:1 and 86mm bore. if anyone thinking i'm looking at k20a specs i don't know if the displacement will match. I think if we can get those numbers in the block without turbo we can get a better powerband. i'm am looking to try and build both a d17a2 and k20a for my ride. to see which one would pan out better in the long run. i know that everyone swears by k20a like skunk2 did the 700hp monster, but the engine we have basically can do better imo.
Old Aug 30, 2008
civic-driver's Avatar
civic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond repute
double post
Old Aug 30, 2008
its physically not possibly to bore a d17 to and 86mm bore not even close. 78mm is what most sleeving companies like darton recommend at the highest to remain safe. at like 80mm im pretty sure the all the cylinders would become one... high comp would be nice but no one has done it. with a 77mm bore i think it puts us to about 1.8 liter and with a 78mm at short 1.9 liter if i remember correct.
