Replacing TSI system with AEM
Old Jul 25, 2007
PitchBlack's Avatar
PitchBlack is just really nicePitchBlack is just really nicePitchBlack is just really nicePitchBlack is just really nice
So I'm replacing my TSI fuel system this weekend with the new AEM fuel management system. I am using stock injectors with the additional two from the TSI injector block. My question is will my standard 4 injectors be enough to handle the injection required or will I have to keep the 2 extra injectors and use the AEM system to control them as well? Or should I ditch the TSI injector block and just get the RSX injectors? Any input would be appreciated!
Old Jul 25, 2007
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
Re: Replacing TSI system with AEM
i think everyone will agree with rsx injectors. it will be a lot easier to tune and its just less of a hassle rather than screwing around with the tsi injector box.
Old Jul 25, 2007
ronaldo9's Avatar
RSX injectors or srt 4 injectors ftw. I urge you not to use stock injectors on a turbo setup. They are only good to like 3 psi if that and the tsi fuel system is not a safe way of tuning since its simply adding fuel like nitrous.
Old Jul 25, 2007
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
I'm doing same thing, replacing TSI unit with AEM F/IC.
AEM cant control uneven number of additional injectors, unless you'll use 4 extra of them, one per each stock injectors.
I've replaced stock ones with SRT-4 ones, with correction factor of -57%.
For now I run both together F/IC and TSI unit.
I'm playing with F/IC and learning how to tune it.
Old Jul 26, 2007
dezod's Avatar
7thgen Power Maker
I would recommend using larger injectors without a doubt. I will look into a way for you guys to continue to use the up stream injectors from the TSI injectors and the F/IC.
Old Jul 26, 2007
dezod's Avatar
7thgen Power Maker
After consulting with John at AEM, this is possible. Here is how it has to be done:
Use two of the injector inputs and TAP into the primary injectors. Use those two injector outputs to drive 2 additional injectors. They will get their phasing and PW info from the tapped injectors. Put -100% in the maps to turn them off. 0 in the map will give the SAME PW to the upstream injectors as the primary injectors.
Old Jul 26, 2007
PitchBlack's Avatar
see, and thats why we love you guys at Dezod...who else would look out for us besides our mothers if not for you! lol thanks man
Old Jul 28, 2007
any updates?
Old Jul 28, 2007
PitchBlack's Avatar
just installed it tonight so not 100% sure if everything is correct. I didn't want to spend anymore time today on it. I'll post up when I have some new info but everything looks good so far...I'm keeping my fingers crossed
Old Jul 30, 2007
You did not use PnP wiring harness?
With harness it took me 30-45 min to do install.
cukaracha
May 16, 2015 07:36 PM
tylerginevan
Apr 27, 2015 12:29 PM
thesushiboy
Apr 12, 2015 02:54 AM
deception420
Dec 6, 2001 02:31 PM
dubbc
Nov 29, 2001 06:20 PM
