rsx-s injector set-up problem? please help!
Old May 17, 2007
civ_nate's Avatar
civ_nate is an unknown quantity at this point
im posting this up on both hondatech.com and civicforums.com. On civicforums.com i have been told repetedly that under approx. 10psi boost you can run RSX-S injectors on my D17A1. after researching a fair amount i have found that most boosted 01-05 civics use these injectors if they are running lower then 10psi and have yet to come across any negative comments from using these and/or horror stories. after purchasing them, a friend of mine just playing around on CROME made a map which would replecate the one i would use on my civic. Upon doing this, he found that a 340cc injector would max out @ around 4psi. my question is if these injectors will work @ 8psi like i am planning and please explain why/why not.
thanks guys, appreciate your time and help!
Old May 17, 2007
andyman97's Avatar
Turbo Guru
Re: rsx-s injector set-up problem? please help!
You aren't running crome and your car is a d17, not something else. There is a link in my sig on how to appropriately size your injectors to your setup. Its BSFC and HP, not PSI. This has been covered repeatedly.
green01civic
Apr 29, 2015 01:36 PM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
CiviCKiD
Jan 7, 2002 01:30 AM
