Help with identifying RSX Injectors!!!!
Old Apr 17, 2007
boostedEL's Avatar
boostedEL is an unknown quantity at this point
So i got my car running and idling fine. got Chris to help me but every time i hit boost, i lean out. now i have the walbro 255lph pump and assuming that i have rsx-s injectors. i bought them on ebay but not sure if they are. the number on it is QL20 and BBH and i need to know if they are type s or not!!!
Old Apr 17, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
Re: Help with identifying RSX Injectors!!!!
Well depending on how much boost you're running and how much power you're putting down, you may be exceeding them. Is it tuned and you have this issue? Or are you running someone elses map?
Old Apr 17, 2007
boostedEL's Avatar
Well im using Cris's base map and going from that, also hes helpping me tunning my car but all i wanna know if those are the right injectors
Old Apr 18, 2007
andyman97's Avatar
Turbo Guru
There may not be a specific identifier on the injector itself. I think the only way to know for certain is going to be a flow test.
Old Apr 18, 2007
boostedEL's Avatar
Does anybody have a set of type-s injectors in their hands? if so let me know whats written on it and ill compare it to mine of if you have just rsx injectors not type-s.
Old Apr 20, 2007
dezod's Avatar
7thgen Power Maker
Do they have a part number stamped on them? Just go to a local dealership and they can help you. Otherwise, send them to get flow test and clean....
Old Apr 20, 2007
boostedEL's Avatar
I went to acura and they couldn't help me. doesnt matter now, im getting srt-4 injectors. hopefully those will work nice. reason im doing such is that im tired of running lean in boost so ill put those injectors and if that does not fix the problem, ill have a kit for
sale!
runawaykinms
15
Mar 22, 2019 10:32 AM
Bruce2
Sep 27, 2015 08:45 PM
Luluharp
Sep 27, 2015 11:56 AM
PunX
Sep 23, 2015 10:45 PM
charmon4815
General
Sep 22, 2015 08:00 AM
