EL mani comin back? MAYBE so...
Old May 16, 2007
  #61
andyman97's Avatar
Turbo Guru
Re: EL mani comin back? MAYBE so...
Originally Posted by dezod
Well on the same premise, this manifold is not intended for people who are not planning on boosting atleast 12+ PSI on an aggressive T3/T4. A log will be more than fine for the type of boost you're running.
Wasn't this exactly why you only made a handful of EL's in the first place, then stopped making them? Everyone on the forum HAD to have one, then they were available finally and 2 or 3 people actually bought one....
Old May 16, 2007
  #62
dezod's Avatar
7thgen Power Maker
Yes but now this market is in a new plateau with several higher HP cars, showing the power potential. With our IM and head, big power like yours and Hani's will be easy to ascertain.
Edit: Also this is a bit different as I have 4 people with down deposits waiting for these units.
Old May 16, 2007
  #63
Michalo187's Avatar
Abortion Survivor
so if i run high levels of boost on a 38mm it may become dangerous? or is it just more efficient to use 44mm?
Old May 16, 2007
  #64
Michalo187's Avatar
Abortion Survivor
speaking of this when will the head and im be availableand is the im going to be top mount or side mount?
Old May 16, 2007
  #65
dezod's Avatar
7thgen Power Maker
Side. Will be easier feeding even distribution of airflow to each of the cylinders.
Head will be available next week
Old May 16, 2007
  #66
dezod's Avatar
7thgen Power Maker
It may. The manifold design and turbo used will dictate this heavily.
Old May 16, 2007
  #67
exturbo6's Avatar
cant wait for the IM to come out also...its just keeps on getting better..thanks mang!
Old May 16, 2007
  #68
cleanmagcivic's Avatar
cleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trusted
ok we know what the el looks like and good start on the im i will put a deposit down for that then over the el.
Old May 17, 2007
  #69
exturbo6's Avatar
cant wait to get mines.....woot woot.
davidpaustin
May 20, 2015 12:59 PM
Geoff_Geoff
16
Apr 30, 2015 12:17 AM
CascadiaBlue
Apr 18, 2015 09:13 AM
blueracer
Nov 11, 2001 09:54 PM
