Code P0507 On Turbo 05 Civic
Old Feb 15, 2007
ST8RACE's Avatar
ST8RACE has a spectacular aura aboutST8RACE has a spectacular aura aboutST8RACE has a spectacular aura about
INSTALLED TSI TURBO KIT AND BIGGER THROTTLE BODY .GOT IT RUNNING WITH NO OIL LEAKS. NO WHEN AT IDLE TRYING TO DO A IDLE LEARN PROCESS.FOUND TO BE GETTING A CODE P0507 IDLE CONTROL SYSTEM RPM
HIGHER THAN EXPECTED . IF ANY ONE HAS ANY IDEAS. IM ALL EARS.
THANKS
Old Feb 15, 2007
skipbarber's Avatar
check the TPS and IAC connections, make sure they are plugged in all the way.
Old Feb 15, 2007
ST8RACE's Avatar
The Basics Have Been Covered . Connections Are Good, No Throttle
Body Leak, No Intake Leak, Trying To Adjust The Tps To 0.50 Volts
And Adjust Idle And Try The Idle Learn Procedure Again . Thanks
For Any Help Regarding This Problem.
Old Feb 15, 2007
tfnaaf's Avatar
BLDNPSI Mod
im guessing relearn the idle...
Old Feb 15, 2007
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
i would have said tps as well. alas, i am no help...
Old Feb 20, 2007
dezod's Avatar
7thgen Power Maker
I would say it has to do with your larger TB.
Larger TBs deliver more air per the opening of the throttle plate. The ECU thinks it has an idle problem and can not correct it enough of the delivery because it keeps seeing a lean scenario as a result of the increased air flow.
rcolosi
Apr 29, 2015 07:48 PM
tylerginevan
Apr 27, 2015 12:29 PM
dooner24
Apr 14, 2015 07:51 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
civicPesek
Nov 7, 2001 11:33 PM
