Looking To Tape Into The Brake Booster For Boost Gauge
Old Feb 17, 2007
ST8RACE's Avatar
ST8RACE has a spectacular aura aboutST8RACE has a spectacular aura aboutST8RACE has a spectacular aura about
Looking To Tape My Boost Gauge Into The Brake Booster Any Ideas About Going About It , Wth Creating A Vac Leak. Is There Any Splitters That Go From The Bigger Hoses To The Small Vac Lines That Are Needed . If Any One Has Any Ideas ,let Me Know. Thank You.
Old Feb 17, 2007
skipbarber's Avatar
tape probably wont work. the brake booster line might be too big to tap into just to run a gauge, youd have to get a Tee and probably one or two reducers. if you look underneath the throttle cable, you can see another vacuum line going undereath the intake manifold. it goes to the PCV, and it's significantly smaller and would only require a Tee.
Old Feb 17, 2007
ST8RACE's Avatar
ANOTHER USER HERE TOLD ME I NEED A VAC MANIFOLD, IM ON THE RIGHT ROAD HERE KNOW THANK YOU . JUST NEED TO BUY ONE . WITH THE VAC. MANIFOLD I CAN TIE IN MY BLOW OFF VALVE,GAUGE,MAP SENSOR, BOOST CONTROLLER WITH NO LEAKS AND PROBLEMS.
Old Feb 18, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
you need a 3/8" fuel pressure guage tap and a 1/8 NPT to hose barb fitting which will screw into the port in the side of the tap.
Cut the booster hose between the IM and the check valve.
Old Feb 18, 2007
tfnaaf's Avatar
BLDNPSI Mod
You need one of these...
Old Feb 18, 2007
skipbarber's Avatar
^thats what i used, works great.
Old Feb 18, 2007
tfnaaf's Avatar
BLDNPSI Mod
yeah same here, i put a nipple on the end that has a plug then installed it inline with the booster
Old Feb 18, 2007
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
I think this what you're looking for:
https://www.civicforums.com/forums/7...cuum-line.html
Also this is the list of my threads, some of them are related toTSI install, read'em and you'll learn something you seems need to know.
https://www.civicforums.com/forums/s...5&pp=25&page=2
Old Feb 18, 2007
skipbarber's Avatar
i thought about doing it that way too, but i figured youd need just as many extra hoses and adapters either way. If someone reading this attempts to do it in-line as well, just keep in mind that the brake booster has a check valve in it to prevent positive pressure in the brake booster.
Old Feb 20, 2007
dezod's Avatar
7thgen Power Maker
Called a vac manifold.
cukaracha
30
Jul 26, 2015 12:01 PM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
cgavin1
Jul 7, 2015 07:10 AM
Causemo
Jul 5, 2015 06:42 AM
